BettyIsBoop 5 Posted ... Hi, Seems your DNS are outdated See sample with mappy.com But have it too for some other website. Can you check what happen ? Thank you. Quote Share this post Link to post
Staff 10427 Posted ... @BettyIsBoop Hello! We're going to look into the issue. Since you get SERVFAIL, the mappy.fr authoritative DNS might be down or more probably it's blocking some or all of our VPN servers. Can you also tell us which VPN server(s) you experience this problem on? Kind regards Quote Share this post Link to post
BettyIsBoop 5 Posted ... On 12/14/2023 at 2:11 PM, Staff said: @BettyIsBoop Hello! We're going to look into the issue. Since you get SERVFAIL, the mappy.fr authoritative DNS might be down or more probably it's blocking some or all of our VPN servers. Can you also tell us which VPN server(s) you experience this problem on? Kind regards Deactivate VPN, using https://www.fdn.fr/actions/dns/ and it's OK. But today : seems OK too . have issue with https://survey-consulting.com/ too $ dig survey-consulting.com ; <<>> DiG 9.18.19-1~deb12u1-Debian <<>> survey-consulting.com ;; global options: +cmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 56474 ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1 ;; OPT PSEUDOSECTION: ; EDNS: version: 0, flags:; udp: 512 ;; QUESTION SECTION: ;survey-consulting.com. IN A ;; Query time: 3231 msec ;; SERVER: 10.30.50.1#53(10.30.50.1) (UDP) ;; WHEN: Mon Dec 18 11:09:39 CET 2023 ;; MSG SIZE rcvd: 50 $ dig survey-consulting.com @80.67.169.12 ; <<>> DiG 9.18.19-1~deb12u1-Debian <<>> survey-consulting.com @80.67.169.12 ;; global options: +cmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 20821 ;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1 ;; OPT PSEUDOSECTION: ; EDNS: version: 0, flags:; udp: 1232 ;; QUESTION SECTION: ;survey-consulting.com. IN A ;; ANSWER SECTION: survey-consulting.com. 86400 IN A 37.61.203.152 ;; Query time: 44 msec ;; SERVER: 80.67.169.12#53(80.67.169.12) (UDP) ;; WHEN: Mon Dec 18 11:09:30 CET 2023 ;; MSG SIZE rcvd: 66 (but here : website disable access too) Quote Share this post Link to post
