alibaba999xxx1
Playstation remote play port forwarding
Probably there is no adequate solution, but still going to ask.
I have PS4 connected through AirVPN (over Pfsense router). In order to access PS remote play (e.g. SETUP) while away from home, I'd need to open up ports 9295, 9296, 9297 (all already reserved by other users) + 987 (under 2048, not available in AirVPN). Is there some alternative configuration/setup in order to get this to work?
You could forward random remote ports which forward to local ports 9295-9297 + 987, but whether others would be able to join your games is another question.
