Not connected, Your IP: 216.73.216.19
5a515f58660204572434ddccba
ANSWERED Add option to make Eddie prefer Wireguard over OpenVPN
I am using Eddie on Mac but it prefers to use OpenVPN instead of Wireguard for some reason. I want to use Wireguard when possible (my network supports it) for the speed and latency benefits. Please add an option to add a preferred protocol.
The option you ask for is already implemented. You can change connection mode by selecting "Preferences" > "Protocols" from Eddie's main window. Uncheck "Automatic", select a line with WireGuard connection and click "Save". Eddie does not change connection mode by itself, the "Automatic" option in reality is just fixed at the moment to OpenVPN, UDP, port 443.
