debounce
AirVPN Suite 1.3.0 & Wireguard
Hi All,
I am running Ubuntu 22.04.  I have installed AirVPN Suite 1.3.0 with bluetit service running successfully.  I would like to use wireguard instead of openVPN with bluetit.  It seems bluetit is not connecting via wireguard and instead uses OpenVPN.  These are the steps I have taken:
1. installed apt package wireguard
2. configured wireguard public and private keys into /etc/wireguard/
3. Configured bluetit via /etc/airvpn/bluetit.rc with "airvpntype wireguard" to enable wireguard
When I issue goldcrest --recover-network, here is the output:
Goldcrest - AirVPN Bluetit Client 1.3.0 - 1 June 2023
2023-11-01 22:13:25 Reading run control directives from file /root/.config/goldcrest.rc
2023-11-01 22:13:25 Bluetit - AirVPN OpenVPN3 Service 1.3.0 - 1 June 2023
2023-11-01 22:13:25 OpenVPN core 3.8.4 AirVPN linux x86_64 64-bit
2023-11-01 22:13:25 Copyright (C) 2012-2022 OpenVPN Inc. All rights reserved.
2023-11-01 22:13:25 OpenSSL 3.0.2 15 Mar 2022
2023-11-01 22:13:25 Bluetit does not need a network recovery.
2023-11-01 22:13:25 Bluetit session terminated
/var/log/syslog shows bluetit is still trying to connect via WireGuard but it is not supported:
Nov  1 22:08:59 bluetit: Successfully connected to D-Bus
Nov  1 22:08:59 bluetit: Reading run control directives from file /etc/airvpn/bluetit.rc
Nov  1 22:08:59 bluetit: IPv6 is available in this system
Nov  1 22:08:59 bluetit: System country set to US by Bluetit policy.
Nov  1 22:08:59 bluetit: Default VPN type for AirVPN connections is set to WireGuard
Nov  1 22:08:59 bluetit: Forbid quick connection to home country is enabled by Bluetit policy
Nov  1 22:08:59 bluetit: Bluetit successfully initialized and ready
Nov  1 22:08:59 bluetit: Enabling persistent network filter and lock
Nov  1 22:08:59 bluetit: Network filter and lock are using nftables
Nov  1 22:08:59  bluetit: Successfully loaded kernel module nf_tables
Nov  1 22:08:59 bluetit: WARNING: ufw is running on this system and may interfere with network filter and lock
Nov  1 22:08:59 bluetit: Network filter successfully initialized
Nov  1 22:08:59 bluetit: Persistent network filter and lock successfully enabled
Nov  1 22:08:59 bluetit: ERROR: Cannot start AirVPN boot connection. WireGuard VPN connection is not supported yet.
Nov  1 22:08:59 bluetit: AirVPN Manifest updater thread started
Nov  1 22:08:59  bluetit: AirVPN Manifest update interval is 15 minutes
Nov  1 22:08:59 bluetit: AirVPN Manifest update suspended: AirVPN boot connection initialization in progress
Nov  1 22:08:59 bluetit: Trying to load the local instance of AirVPN Manifest
Nov  1 22:08:59  bluetit: AirVPN Manifest successfully retrieved from local instance
Is it correct AirVPN 1.3.0 does not support wireguard?
  Edited ... by debounce
