ProdBreakingMonkey
ANSWERED WireGuard W/Multiple Clients
Good day, I'm looking to migrate from the OVPN to WireGuard connections on my router, but due to the way that WG requires a local peer IP as part of the connection it means that I have 2 separate IPs assigned, otherwise I'm unable to create the interfaces to route traffic through. When I use the config generator though it always has the same IP in the 'Address = ' parameter. Is there a way around this limitation?
You can consider to generate different keys for your account in your AirVPN account "Client Area" > "Devices" panel, so you will get different VPN IP addresses for different profiles based on different keys. Please see here:
