deptofrichie
Poor P2P speeds
hi
been using Airvpn with u torrent for about a year now and generally v.happy, on a 60meg cable connection its not unusual to see 1 to 2Mb/s p2p and 30M/s speedchecked over vpn.
about a week ago something changed and now i seem to max out at <100k/s p2p but still test quite well on a speed check..
thinking it was utorrent i've tried a different client (Tixalti) but the speeds remained much the same.
tonight i've noticed if i run tixalti with the VPN off i get 1M/s. turn the VPN on and it drops back to <100k.
any ideas what he problem is? I've set up port forwarding but its made no difference.
any hekp appreciated.
hi
been using airvpn for abput a year with utorrent and always been harpy.
on a 30meg cable connection i used to get about 1Mb/s downloads.
about a week ago something changed and i now cap out at 100k/s
thinking this was a utorrent problem i switched to Tixatil but speed have not improved.
tonight i used Tixalti without airvpn and i'm back to getting 1M/s p2p. turn on Airvpn and it drops to <100k/s.
anyone any ideas what the problem might be? I've set up port forwarding but that's not helped. could it be a firewall issue? if so, any suggestions where to start?
Help much appreciated.
