elyflo01 0 Posted ... Is it beneficiary to turn on lock current with port forwarding in eddie for seeding torrents? Quote Share this post Link to post
Staff 10489 Posted ... Hello! Pros: in case of disconnection, Eddie will re-connect to the same server and your seeding IP address will not change on the swarm, allowing immediate re-connections by all peers that discovered you. Cons: if the server your system is connected to goes down Eddie will not be able to re-connect (Network Lock will anyway prevent any possible traffic leak). Kind regards 1 elyflo01 reacted to this Quote Share this post Link to post
