Not connected, Your IP: 3.141.45.137
Staff
Linux: AirVPN Suite 2.0.0 preview available
We're very glad to inform you that AirVPN Suite version 2.0.0 alpha 1  is now available.
UPDATE 2023-11-24: version 2.0.0 alpha 2 is now available.
UPDATE 2024-05-14: version 2.0.0 beta 1 is now available.
UPDATE 2024-12-16: version 2.0.0 beta 2 is now available.
AirVPN Suite 2.0.0 introduces AirVPN's exclusive per app traffic splitting system as well as some bug fixes, revised code in order to pave the way towards the final and stable release, WireGuard support, and the latest OpenVPN3-AirVPN 3.9 library. Please see the respective changelogs for a complete list of preliminary changes for each component of the suite. If you feel adventurous and you wish to test this beta version, please feel free to report any glitch, bug and problem in this very thread.
The 2.0.0 Beta 2 Suite includes:
  • Bluetit: lightweight, ultra-fast D-Bus controlled system daemon providing full connectivity and integration to AirVPN servers, or generic OpenVPN and WireGuard servers. Bluetit can also enforce Network Lock and/or connect the system to AirVPN during the bootstrap
  • Goldcrest: Bluetit client, allowing full integration with AirVPN servers, users, keys, profiles as well as generic OpenVPN and WireGuard servers
  • Hummingbird: lightweight and standalone binary for generic OpenVPN and WireGuard server connections
  • Cuckoo: traffic split manager, granting full access and functionality to AirVPN's traffic split infrastructure
  • airsu: a "run and forget" tool to automatically set and enable the user environment for the X.Org or Wayland based ecosystem without any user input
WireGuard support
WireGuard support is now available in Bluetit and Hummingbird. OpenVPN or WireGuard selection is controlled by Bluetit run control file option airvpntype or by Goldcrest option -f  (short for --air-vpn-type). Possible values: openvpn, wireguard. Default: openvpn. The option is documented in the 1.3.0 manual as well.
Bluetit run control file (/etc/airvpn/bluetit.rc) option:
airvpntype: (string) VPN type to be used for AirVPN connections. Possible values: wireguard, openvpn. Default: openvpn
Goldcrest option:
--air-vpn-type, -f : VPN type for AirVPN connection <wireguard|openvpn>
Suspend and resume services for systemd based systems
For your comfort, the installation script can create suspend and resume services in systemd based systems, according to your preferences. allowing a more proper management of VPN connections when the system is suspended and resumed. The network connection detection code has also been rewritten to provide more appropriate behaviour.
Asynchronous mode
A new asynchronous mode (off by default) is supported by Bluetit and Goldcrest, allowing asynchronous connections. Network Lock can be used accordingly in asynchronous connections. Please consult the readme.md file included in every tarball for more information and details.
Word completion on bash and zsh
Auto completion is now available by pressing the TAB key when entering any Goldcrest or Hummingbird option and filename on a bash or zsh interpreter. Auto completion files are installed automatically by the installation script.
AirVPN's VPN traffic splitting
AirVPN Suite version 2.0.0 introduces traffic splitting by using a dedicated network namespace, therefore completely separating the VPN traffic from unencrypted and "out of the tunnel" traffic. The VPN traffic is carried out in the default (main) namespace, ensuring all system data and traffic to be encrypted and tunneled into the VPN by default. No clear and unencrypted data are allowed to pass through the default namespace.
Any optional unencrypted data or clear network traffic must be explicitly requested by an authorized user with the right to run cuckoo, the AirVPN traffic split manager tool.
AirVPN's traffic splitting is enabled and controlled by Bluetit and by means of run control directives. The system has been created in order to minimize any tedious or extensive configuration, even to the minimal point of telling Bluetit to enable traffic splitting with no other setting.
In order to enable and control AirVPN's traffic splitting, the below new run control directives for /etc/airvpn/bluetit.rc have been introduced:
  • allowtrafficsplitting: (on/off) enable or disable traffic splitting (unencrypted and out of the tunnel traffic) Default: off
  • trafficsplitnamespace: (string) name of Linux network namespace dedicated to traffic splitting. Default: aircuckoo
  • trafficsplitinterface: (string) name of the physical network interface to be used for traffic splitting. All the unencrypted and out of the tunnel data will pass through the specified network device/interface. In case this directive is not used and unspecified, Bluetit will automatically use the main network interface of the system and connected to the default gateway. Default: unspecified
  • trafficsplitnamespaceinterface: (string) name of the virtual network interface to be associated to the Linux network namespace dedicated to traffic splitting. Default: ckveth0
  • trafficsplitipv4: (IPv4 address|auto) IPv4 address of the virtual network interface used for traffic splitting. In case it is set to 'auto', Bluetit will try to automatically assign an unused IPv4 address belonging to the system's host sub-network (/24) Default: auto
  • trafficsplitipv6: (IPv6 address|auto) IPv6 address of the virtual network interface used for traffic splitting. In case it is set to 'auto', Bluetit will try to automatically assign an unused IPv6 address belonging to the system's host sub-network (/64) Default: auto
  • trafficsplitfirewall: (on/off) enable or disable the firewall in Linux network namespace dedicated to traffic splitting. The firewall is set up with a minimal rule set for a very basic security model. Default: off
AirVPN's traffic splitting is designed in order to minimize any further configuration from the system administrator. To actually enable traffic splitting, it is just needed to set "allowtrafficsplitting" directive to "on" and Bluetit will configure the traffic split namespace with the default options as explained above. When needed, the system administrator can finely tune the traffic splitting service by using the above directives.
Power and limitations
The adopted solution offers a remarkable security bonus in terms of isolation. For example, it gets rid of the dangerous DNS "leaks in" typical of cgroups based traffic splitting solutions. However, the dedicated namespace needs an exclusive IP address. If the system is behind a NAT (connected to a home router for example) this is not a problem, but if the system is not behind any NAT, i.e. it is assigned directly a public IP address, you will need another public IP address for the network namespace dedicated to traffic splitting. You will need to manually set the other public IP address on the trafficsplitipv4 or trafficsplitipv6 directive as the guessing abilities of Bluetit may work only within a private subnet. Please keep this limitation in mind especially if you want to run the Suite with per app traffic splitting on a dedicated or virtual server in some datacenter, as they are most of the times NOT behind any NAT.
Introducing Cuckoo, the AirVPN traffic splitting manager tool
Bluetit supports and implements a traffic splitting facility by using a dedicated network namespace.
AirVPN Traffic splitting is implemented by using a separate and independent network namespace, directly communicating with the system’s default gateway through a virtual interface associated to a physical network interface available in the system. This ensures a true separation of traffic between tunneled and encrypted VPN data from the unencrypted and clear data to be channeled out of the VPN tunnel. The unencrypted traffic generated within the traffic splitting network namespace will never pass through the default (main) namespace - which is under the VPN control - including, and most importantly, DNS requests.
To generate unencrypted and out of the tunnel traffic, any application software must be run inside the traffic split namespace by using the dedicated traffic split tool cuckoo which can be run by users belonging to the airvpn group only and it cannot be used by the superuser.
The usage is documented in the manual as well as on the inline help.
The traffic split namespace uses its own routing, network channels and DNS. It will not interfere or communicate in any way with the default namespace using its own encrypted tunnel. As for DNS, the traffic split namespace will use default system DNS settings.
Programs started with cuckoo are regular Linux processes and, as such, can be managed (stopped, interrupted, paused, terminated and killed) by using the usual process control tools. The programs started by cuckoo are assigned to the user who started cuckoo.
As a final note, in order to work properly, the following permissions must be granted to cuckoo and they are always checked at each run.
  • Owner: root
  • Group: airvpn
Permissions: -rwsr-xr-x (owner can read, write, execute and setuid; group can read and execute, others can read and execute)
AirVPN Switch User Tool Airsu
Running an application in a graphical environment requires a user having a local environment properly set, in particular variables and access to specific sockets or cookies. They are usually set at the moment of graphical login, while they may not be properly set in case a user logged in by using the system tool su.
In this specific case the user will not probably be allowed to access the graphical environment, so any GUI application will not start.
AirVPN’s airsu is used for this specific purpose and configures the user environment to the current X.Org (X11) or Wayland based manager, thus allowing access to GUI applications when run through cuckoo.
Note on GUI software and Web Browsers
The previous limitations on browsers have been completely resolved. Furthermore, complete compatibility with Wayland based environment has been implemented.
Because of the specific Linux architecture and namespaces, some applications may need to specify the graphical environment in order to start and use the currently selected window manager on an X.Org (X11) or Wayland based habitat. Cuckoo can automatically do this by “injecting” predefined options to some preset applications, in particular those based on the chromium engines, most of them being web browsers. To see the list of predefined applications, please start cuckoo with --list-preset-apps option.
When running an application with cuckoo, the user should make sure to actually start a new instance. This is usually granted by starting an application from the command line (such as running it with cuckoo). By starting an application from the desktop environment this may not happen.
Download AirVPN Suite 2.0.0 beta 2
ARM 64 bit:
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-aarch64-2.0.0-beta-2.tar.gz
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-aarch64-2.0.0-beta-2.tar.gz.sha512
ARM 64 bit legacy:
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-aarch64-legacy-2.0.0-beta-2.tar.gz
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-aarch64-legacy-2.0.0-beta-2.tar.gz.sha512
ARM 32 bit:
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-armv7l-2.0.0-beta-2.tar.gz
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-armv7l-2.0.0-beta-2.tar.gz.sha512
ARM 32 bit legacy:
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-armv7l-legacy-2.0.0-beta-2.tar.gz
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-armv7l-legacy-2.0.0-beta-2.tar.gz.sha512
x86-64:
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-x86_64-2.0.0-beta-2.tar.gz
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-x86_64-2.0.0-beta-2.tar.gz.sha512
x86-64 legacy:
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-x86_64-legacy-2.0.0-beta-2.tar.gz
https://eddie.website/repository/AirVPN-Suite/2.0-Beta2/AirVPN-Suite-x86_64-legacy-2.0.0-beta-2.tar.gz.sha512
Changelogs
Changelogs are available inside each package.
Kind regards & Datalove
AirVPN Staff
Hi. I'm trying to get up and running but I am having some trouble. please assist.
I have installed the package, the installer created the airvpn user and group, I then ran cuckoo [program] from the airvpn user. I get the following error message
Cuckoo - AirVPN Traffic Split Manager 2.0.0 alpha 1 - 15 Sep 2023
ERROR: Cannot open network namespace 'aircuckoo': No such file or directory
Hello and thank you for your tests!
Can you please make sure that you have the following directive in /etc/airvpn/bluetit.rc
allowtrafficsplitting on
If this is missing you will get that error message. We will make that error message more explicative during the alpha stage. Please let us know whether the problem is caused by the missing directive or not.
On 9/15/2023 at 12:00 PM, Staff said:
Note on DNS and Gecko or Chromium Based Web Browsers
Not that I am into traffic splitting, not at all, but just to test the new Suite I think I would resolve the problem by having split Firefox environments: different datadir, profiles etc. Before I try, do you think it can work? I guess it might be overkill, if someone found a smoother solution let me know...
Yes I have this setting and I am still receiving the same error.
I was also dealing with an issue that airvpn changed the /etc/resolv.config file. I had to delete the file contents and add my DNS to the nameserver to regain internet access
Thanks. Thus, it must be a different issue or maybe a bug. Can you tell us your distribution name and version? Can you also please send us the complete Bluetit log? You can see it via journalctl if you are in a systemd based distribution. The following command:
sudo journalctl | grep bluetit > bluetit.log
will store the whole log in bluetit.log file.
When this other problem occurs, please send us a Bluetit log again as well as the content of the /etc/airvpn directory:
sudo ls -l /etc/airvpn
Unfortunately it will not work. We are investigating different issues caused by web browsers. Please check the original announcement, we have changed a part to reflect the matter, we paste it here for readers' comfort and in order to outline the issue:
Note on Web Browsers
Firefox and Chromium will not be able to resolve names in the aircuckoo namespace, not even when you run a unique instance of them inside the network namespace itself, in some Ubuntu systems. We are investigating this behavior. Brave, Opera and Konqueror are not affected by this problem, but please consider that due to how browser instances are tied to each other, you might get unexpected behavior if you run the same browser in both namespaces from the same user.
For example, if the browser has been started in the default namespace while there is an active AirVPN connection, the traffic will flow to the connected AirVPN server and from the associated VPN IP address from any future apparent instance launched by the same user, and vice-versa. The second instance may detect the first, delegate the task to it and exit, so you will have a new window but not another instance.
In order to circumvent the issue, at this stage you may tale care to run programs in the aircuckoo namespace via cuckoo only from airvpn account, and programs whose traffic must be tunneled from your ordinary account. In other words, to add security, do not add your ordinary account to the airvpn group if you plan to use traffic splitting, so your ordinary account will not be able to run cuckoo by accident.
Glad to see this preview. Questions: shall we see a port to FreeBSD of the whole Suite? Can we expect app based traffic splitting on Windows?
if the browser has been started in the default namespace while there is an active AirVPN connection, the traffic will flow to the connected AirVPN server and from the associated VPN IP address from any future iapparent instance, and vice-versa. The second instance may detect the first, delegate the task to it and exit, so you will have a new window but not another instance.
Is it just me or is it a severe problem? I mean, if cuckoo just forces an app to run in a specific network namespace with no other process isolation whatsoever then not only browsers but also any program checking whether another instance of itself is already running in order to share resources or opt for delegations will cause all sort of troubles to the unaware user. Was the first instance launched in the root namespace or in the cuckoo namespace? Was another instance running because it started at boot? How the user is supposed to remember and track all the instances and know which programs check for another instance of themselves when starting?
Waiting for developers answers and hoping that, if I'm correct, this unhappy preview is just a bump in the road, after all it's only alpha 1.
Of course, as you say, this is an early preview, an alpha 1, so we can and we will improve the software. With the understanding the the highest security level is reached only by renouncing to traffic splitting or by splitting traffic only through boosted virtualization via a proper hypervisor, our solution aims at offering a fair balance between a very light implementation and a safe environment. If we pushed on virtualization too much, then the user might as well use directly pushed solutions of non-Linux third-party components and software suites, such as VirtualBox or Docker. It's not in our vision to burden the AirVPN Suite at those levels, as the Suite is thought to remain the most lightweight piece of software we release.
In the current default setup, you have a minimum of two separate login users in any Linux box: airvpn and your usual user. By default, only airvpn can run cuckoo. If you consider not to add your current user to the airvpn group, you can safely rely on the fact that the types of processes you mention launched by your current user will never be affected by processes started by airvpn user and vice-versa. In this way it's almost impossible to cause a confusion by distraction and, for example, using a browser outside the tunnel while you think that it's inside.
It's also obvious that a decent concentration level is always required, but that's required even with full virtualization, because no security model can save you from the distraction to assume wrongly that a specific VM is connected to the VPN while in reality it is not. So nothing new, traffic splitting was, is and will be requiring some attention, no matter how you achieve it. Stay tuned for the alpha 2, we are working on it.
We're terribly sorry, the port to FreeBSD is currently frozen. We will re-consider it anyway in the future, but only after the Suite 2 stable version for Linux is released. As far as it pertains to Windows, we will leave the answer to the Eddie Windows edition developer.
It is indeed a severe problem and I don't see a way how this could be fixed. If you chose to separate the IPC/storage namespaces too then you'd need to take full control over application settings and how it's launched to ensure separation.
The main vector here are default protocol handlers. Click an http:// link in any other program and your default browser will start in the default namespace, not that other one. What else can you do, intercept all program launches? Linux doesn't have the same concept of matching an ".exe name" as on Windows.
Edit: I just saw that Staff replied. The per-user separation is a reasonable decision here.
I have a similar issue using a custom namespaced setup with Wireguard but in a different way. Firefoxes' DNS lookups inside the namespace will work until the computer goes to sleep. After waking up Firefox will be unable to resolve any hosts until Fx is restarted. I have not tried loading websites per IP, maybe Firefox actually loses all connectivity in this case. Arch Linux.
Just a guess, did you put a per-namespace resolv.conf file where it belongs? Somewhere around mans/arch wiki or systemd text there was a proposal of a standard to have per network namespace resolver configuration. Maybe Firefox when it doesn't run DoH looks at the wrong resolv.conf and tries to contact the local DNS resolver from another namespace.
Yes, of course, we take care of both resolv.conf and nsswitch.conf inside the aircuckoo namespace (/etc/netns/aircuckoo/nsswitch.conf) in order to
  1. prevent the feared and dangerous "DNS leaks inside then tunnel" which affect other traffic splitting implementations based on cgroups and
  2. cover various distributions, including systems where systemd-resolved runs.
In our "reversed" traffic splitting implementation, the aircuckoo namespace apps must query the system DNS.
Per network namespace resolver configuration seems an established feature, or do you mean something else with the proposal you mention? Or do you imply that systemd-resolved may cause additional problems we have not taken into account?
For your specific problem, we have no immediate suggestion unfortunately, we would just recommend that you check (for example with Wireshark) what happens to Firefox packets after the system woke up. We're also unsure whether this article may help you, probably not but we link it anyway just in case:
https://philipdeljanov.com/posts/2019/05/31/dns-leaks-with-network-namespaces/
Feel free to keep us posted, and we'll do the same, as the different outcome with / behavior of Firefox in different distributions is under investigation and we need to clarify the issue carefully.
@Staff
At the moment I found a solution I like. I enter desktop environments both with airvpn and my normal account at the same time and then switch between the environments. Switching is quite fast on Linux and it helps me focus on which is which. It resolves a problem I met which I did not look into much, maybe you like to hear it. The airvpn account apparently does not get properly configured by the installer or maybe I made some error during installation, because airvpn account via cuckoo can't run any de based application on the desktop of someone else. [virtualized Fedora 38 here].
Hey I found what I was thinking of, man ip-netns:
Quote
DESCRIPTION
      A network namespace is logically another copy of the network stack, with its own routes, firewall rules, and network devices.
      By default a process inherits its network namespace from its parent. Initially all the processes share the same default network namespace from the init process.
      By convention a named network namespace is an object at /var/run/netns/NAME that can be opened. The file descriptor resulting from opening /var/run/netns/NAME
      refers to the specified network namespace. Holding that file descriptor open keeps the network namespace alive. The file descriptor can be used with the
      setns(2) system call to change the network namespace associated with a task.
HERE: For applications that are aware of network namespaces, the convention is to look for global network configuration files first in /etc/netns/NAME/ then in /etc/.
      For example, if you want a different version of /etc/resolv.conf for a network namespace used to isolate your vpn you would name it /etc/netns/myvpn/re‐
      solv.conf.
This is what you already do, nice. However for systemd-resolved I did not find a single mention of network namespaces (i.e. this convention) in their manual. God knows what it does or does not do.
Looking further I found https://github.com/systemd/systemd/issues/17155 - "portable: default profile /etc/resolv.conf bind mount can break in the container namespace." maybe that's similar to my case even though I don't use systemd-resolved (but rebinding happens; I'm not worried about DNS going through main namespace since I use dnscrypt there anyway - my ISP interferes with DNS). Yeah, I really should check Wireshark. For others reading, what's funny is Wireshark not supporting network namespaces yet. You must launch it in the appropriate net ns with enough permissions or Wireshark will not see the other interfaces.
Now an unrelated but good link with explanation of some systemd service options, here the user manually created a service with Wireguard-style netns: https://github.com/systemd/systemd/issues/28694
Here again a lengthy discussion of starting systemd services in a network namespace: https://github.com/systemd/systemd/issues/2741
@Staff
I have been using Bluetit on Debian 11 for more than a year now, and have ran into an issue with SSD activity.
It seems that Bluetit is causing noticeable read/write activity on the SSD.  This completely goes away if I use wireguard, or openvpn that is not running on Bluetit.  Version of Bluetit also doesn't seem to matter, as the same issue persists after updates.  Since the PC stays online 24/7, it is now causing significant wear on SSD.
Is this a known issue?  If not, any suggestions on how to get around this?
@TooLittleTime
We are unable to reproduce the issue at the moment, can you please tell us whether you see the same when you run Hummingbird (with Bluetit not running at all)?
We're glad to inform you that AirVPN Suite 2.0.0 alpha 2 is now available.
NEW:
  • WireGuard support by Bluetit and Goldcrest
  • minor bug fixes
The announcement message has been updated accordingly. Thank you for your tests! Please report bugs or any malfunction here.
Great, it works, and I see dramatic performance increase with WIreGuard and lower CPU load on a level playing field with OpenVPN (same server etc.). It's totally consistent with the wg client for Linux with kernel module. Not my case but out of information what happens if the module is unavailable?
If the WireGuard kernel module is missing, the Suite will not work in WireGuard mode.
Cuckoo - AirVPN Traffic Splitting Manager 2.0.0 alpha 1 - 24 November 2023
$ sudo ls -l /etc/airvpn
total 168
-rw-rw---- 1 root root 138622 Jan 12 10:02 airvpn-manifest.xml
-rw-r----- 1 root root      5 Jan 12 10:02 bluetit.lock
-rw-rw---- 1 root root   3496 Jan 12 09:54 bluetit.rc
-rw-rw---- 1 root root   1445 Jan 12 09:41 connection_priority.txt
-rw-rw---- 1 root root     48 Jan 12 09:41 connection_sequence.csv
-rw-rw---- 1 root root    103 Jan 12 09:41 continent_names.csv
-rw-rw---- 1 root root   1743 Jan 12 09:41 country_continent.csv
-rw-rw---- 1 root root   3737 Jan 12 09:41 country_names.csv
-rw-rw---- 1 root root    225 Jan 12 09:41 nsswitch.conf
getting the same error as above. here's what i changed in bluetit.rc:
airvpntype wireguard
trafficsplitnamespace aircuckoo
distro: debian 12 stable amd64
bluetit.log
edit: i think it's because i didn't set my airvpn username and password 😅 now bluetit starts to connect
Edited ... by irxhnfdptv
@irxhnfdptv
WireGuard can't connect. Might it be blocked in your network? If you try a connection with the native WireGuard client for Linux, is it successful? You can generate a profile for WireGuard on our Configuration Generator available in your AirVPN account "Client Area". By testing the WireGuard client directly you may let us discern whether the problem is Bluetit-specific or not.
16 minutes ago, Staff said:
@irxhnfdptv
hello. yea it works natively if i use "wg-quick up wg0" Edited ... by irxhnfdptv
