casperzero 0 Posted ... So starting sometime this week, I've been unable to connect to AirVPN through eddie, and I can't figure out why. It's been working well from multiple addresses and multiple countries up to now I 2023.09.14 21:54:49 - Ready . 2023.09.14 21:54:51 - Collect information about AirVPN completed I 2023.09.14 21:54:52 - Session starting. I 2023.09.14 21:54:53 - Checking authorization ... . 2023.09.14 21:54:55 - Added new network interface "Eddie", Wintun version 0.12 . 2023.09.14 21:54:55 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2023.09.14 21:54:55 - Connecting to Fawaris (New Zealand, Auckland) . 2023.09.14 21:54:56 - Routes, add 103.231.91.61/32 for interface "ZeroTier One [8056c2e21c3d5959] (ZeroTier Virtual Port)". . 2023.09.14 21:54:56 - Routes, add 103.231.91.61/32 for interface "ZeroTier One [8056c2e21c3d5959] (ZeroTier Virtual Port)", already exists. . 2023.09.14 21:54:56 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2023.09.14 21:54:56 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2023.09.14 21:54:56 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2023.09.14 21:54:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.09.14 21:54:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.09.14 21:54:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.09.14 21:54:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.09.14 21:54:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]103.231.91.61:443 . 2023.09.14 21:54:56 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2023.09.14 21:54:56 - OpenVPN > UDP link local: (not bound) . 2023.09.14 21:54:56 - OpenVPN > UDP link remote: [AF_INET]103.231.91.61:443 . 2023.09.14 21:55:28 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2023.09.14 21:55:28 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.09.14 21:55:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2023.09.14 21:55:34 - Disconnecting . 2023.09.14 21:55:35 - Routes, delete 103.231.91.61/32 for interface "ZeroTier One [8056c2e21c3d5959] (ZeroTier Virtual Port)". . 2023.09.14 21:55:35 - Routes, delete 103.231.91.61/32 for interface "ZeroTier One [8056c2e21c3d5959] (ZeroTier Virtual Port)", not exists. . 2023.09.14 21:55:35 - Connection terminated. Quote Share this post Link to post
ss11 22 Posted ... It looks like it is trying to use an interface (virtual adapter tun/tap) that does not exist, a custom-named one. Did you install Eddie from scratch or copied it in weird way? Anyway, you should go to your network settings and see if you have any tun/tap adapter of custom name, if not remove from Eddie ZeroTier One, run it with default settings. Quote Share this post Link to post
Tech Jedi Alex 1513 Posted ... 1 hour ago, ss11 said: It looks like it is trying to use an interface (virtual adapter tun/tap) that does not exist, a custom-named one. Did you install Eddie from scratch or copied it in weird way? Anyway, you should go to your network settings and see if you have any tun/tap adapter of custom name, if not remove from Eddie ZeroTier One, run it with default settings. You misread the logs, I think. 4 hours ago, casperzero said: . 2023.09.14 21:54:55 - Using WinTun network interface "Eddie (Eddie Tunnel)" It is using the correct interface. The routes are to the AirVPN server, added to the interface Eddie determined to be the primary one, which is ZeroTier Virtual Port. $ curl -s "http://ip-api.com/json/103.231.91.61|jq -r .org AirVPN.org entry server (Fawaris) Try rebooting the machine (not shutdown + startup) and try again. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
casperzero 0 Posted ... I figured it out. I was testing out some VPN thing and forgot to uninstall it Quote Share this post Link to post
Tech Jedi Alex 1513 Posted ... Was it ZeroTier, by any chance? What did you test? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
casperzero 0 Posted ... Not much. Just to port into someone's game because his IP didn't allow him to port forward without jumping through hoops Quote Share this post Link to post
