Not connected, Your IP: 216.73.216.7
Close Eddie, reopen, try a connection. Then provide a support file instead of just logs, please.
Same here, stuck on checking route ipv4, opened ticket, sent logs, no reply yet.
Edited ... by allexstorm
Try changing the port: Eddie Preferences > Protocols > Uncheck Automatic > Select UDP port 53.Alternatively, in Advanced uncheck Check if the tunnel works, then in Network Lock make sure a Mode is selected and Ensure in session is checked.
It might be relevant to know (just in case) that currently connections from Russia, China, Egypt, UAE may work only with OpenVPN in TCP, to port 53 or 443, in tls-crypt (entry-IP address THREE). OpenVPN over SSH is working too.
Connections from Iran do not work, no matter the connection mode you try. To Iranian citizens we recommend Tor obfuscated and private bridges. You will need to update your bridge frequently.
