phillyd32 0 Posted ... I just set up Eddie with AirVPN and got QBittorrent installed to begin torrenting. I followed the Port forwarding config info given by Airvpn for p2p, but I don't think the ports are forwarding. I get error 110 when I click test open on the ports page. Sites like canyouseeme fail to see me in the port too. My set up process: I got a port from the client area > forwarded ports It is set with default config, enabled, tcp/udp, all devices, forwards to the same local port Opened QBittorrent Set Network Interface to Eddie Set the listening port to the one I got on AirVPN Turned off UPnP/NATPMP Applied config and closed QBittorrent Opened Eddie and connected to suggested server Opened QBittorrent Troubleshooting I tried: Checked firewall (turned it off for qbittorrent but nothing changed) Restarted the PC Verified no other network monitoring or VPN type software was running or even installed Removed the port and requested a new one, then did config to that port everywhere. Any ideas? Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... 19 hours ago, phillyd32 said: Checked firewall (turned it off for qbittorrent but nothing changed) Try turning it off completely. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
bluesjunior 48 Posted ... This may or may not help but it is a very good guide to setting up qBittorrent optimally.The Best QBittorrent Settings for Faster Downloads - Tech Junkie Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... 22 hours ago, Benimaru said: I have same problem please help Please open your own thread and outline your setup, what the problem is and what you tried to do so far. Don't hijack the threads of others looking for answers to their issues. Your display name sounds familiar. Is it from TenSura? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
