perton
Master Password on Fire Stick
How does one change the master password on the fire stick?  I forgot it and cannot log into AirVPN.
Please delete all Eddie's local data (not only the cache, all data) from the app settings menu of your FireStick. You will then need to re-enter your AirVPN credentials at the next run. Alternatively uninstall and re-install Eddie. Starting from Eddie 3.0 the Master Password is disabled by default and opt-in.
