alternate
GoodByeAds is blocking google.com ?
I have been using the GoodByeAds (the full list) for a while now and everything was smooth. Recently, I noticed that I cannot access google.com. Consequently, all reCAPTCHA requests are rendered invalid. I dug into the problem and found out that GoodByeAds caused the blockage even though google.com is not on their list
Is there an explanation here ? And what to do to whitelist the domain ?
You might have some luck with opening browser developer tools -> Network. Then reload google.com and notice which requests are red. You need to add these to your Client Area -> DNS -> "Custom answers" section with action "Allow".
That might be because it's not served from google.com. Could be using a subdomain of googleapis.com. You might find that out following Mr. benfitita's way.
