bentaoki
Plex says I'm connectable outside my network for about 3 seconds then says I'm not
Hello, I am trying to host a Plex server using a Windows PC and every time I try to set my port it will say it can connect and then a few seconds later it will say it cannot
I attached a GIF to show my problem
Any help goes a long way 😁
6 hours ago, OpenSourcerer said:
But does a connection to Plex using that port work?
Ok, Apparently it is. I went into a remote computer and checked and it is. Last time this happened it was mad at me about how the quality wouldn't be good or something and I tried to troubleshoot and gave up and just tried again recently. I apologize.
Hi all
you must to edit the file generated by AirVpn (the.ovpn)
just add the followings lines:
# PLEX over WAN
route plex.tv 255.255.255.255 192.168.1.254
after the line remote
client
dev tun
remote vpnserver.xxx.xxx 443
recreate you vpn connection, try and enjoy ;)
don't forget to open the plex port in you box.
best rgds
Nils ;)
On 7/11/2023 at 3:48 PM, Nils95 said:
Hi all
# PLEX over WAN
client
dev tun
best rgds
Nils ;)
Would you know how to adapt this for a WireGuard script?
Many thanks!
