Vana7au4
MusicBrainz.org blocked
To recap, I have created two AirVPN configurations, one which uses Canada servers and the other Japan servers, but neither works.
The problem is related to using the VPN: if AirVPN is disabled, then the connection to www.musicbrainz.org works.
This is using AirVPN:
curl -IL https://www.musicbrainz.org
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to www.musicbrainz.org:443
This is without AirVPN:
HTTP/2 301
server: openresty
date: Mon, 12 Jun 2023 09:49:17 GMT
content-type: text/html
content-length: 166
HTTP/2 200
content-type: text/html; charset=utf-8
content-length: 0
server: Plack::Handler::Starlet
referrer-policy: unsafe-url
  Edited ... by Vana7au4
Same problem here. I'm using Firefox web browser if that helps. Error says something like "PR_CODE_FILE_ERROR", which I looked up and meant something to do with VPN misconfiguration.
I could connect on my phone just fine before, but now it seems to fail across all servers.
https://airvpn.org/routes/?q=https%3A%2F%2Fwww.musicbrainz.org
Edited ... by amuck2702
added error message, routing report, and server used
