3tigerlillies
I need a slight GUI rearrangement
Maybe I am splitting hairs about the GUI in AirVPN here, but it just looks a little odd for me...
In my case, using Linux Mint 21.1, everything works as it should.
But, what I do have, is an issue with the configuration button at the top left of the window, and also the panel daemon.
They show either a context menu, or as a list, with the "Disconnect" option as the second item at the top of the list.
Like this.......
The options (above) appear to be in the wrong place; so I would dearly like to see AirVPN re-situate the options in both the GUI and the panel Daemon as shown below.
The Disconnect option always catches me out and instead of hiding the app's icon in the panel, I end up disconnecting from the session. 😬
My logic would be, to have the Hide Main Window at the top of the list and Disconnect somewhere below, like so;
This appears to be un-editable action, unless one has a deeper knowledge of css.
Is it unreasonable to request a revamp of the GUI?
Would anyone else agree?
