Guest Posted ... Hello Team AirVPN, I have been using VPN services for several years and I keep coming across you guys. I think your values and reputation are very good. The only thing that keeps me from subscribing to you is that you use hard drives. With what I have learned about you, privacy, anonymity is very important to you. Why do you put hard disks in your rented server? Kind regards Quote Share this post Link to post
Staff 10433 Posted ... @AVPN0815 Hello! That's not entirely correct because we use RAM disks. It is true that an HDD or SSD is used to boot, and it contains a working boot record, grub software or similar, used in turn to load a kernel which must provide TCP/IP, network and basic services support, but anything else is downloaded via network (after the network is up, obviously). At each (re)boot the server can not start, because it is barred from downloading any relevant file until we authorize the reboot, so it will miss even the essential configuration files, scripts, keys... This allows us to check the kernel (once the network is up) and any relevant storage file against a pristine copy, especially if the reboot is unexpected. Once the TCP/IP stack, the network and their essential services have come up, and a manual authorization has been dispatched by AirVPN management, the server starts downloading any other file needed for normal operations, and all of that remains in RAM disks. Kind regards 3 t5qxq6TS, Lee47 and flat4 reacted to this Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 11 hours ago, AVPN0815 said: The only thing that keeps me from subscribing to you is that you use hard drives The more interesting question is the source of this information. Would you kindly provide that so it can be corrected? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
flat4 95 Posted ... This is why my subscription is so long the way air does things Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
