nocturnaltabernacle 2 Posted ... I'm seeing some web pages not working through Wireguard while they work through OpenVPN on the same server. For example Firefox status bar might say "Performing a TLS handshake..." and the page loads without images and styles, or the page doesn't load at all. I'm running pfSense 2.6.0 as my router and AirVPN client and I tested from Linux and Mac workstations. What might be the issue? Quote Share this post Link to post
Staff 10427 Posted ... @nocturnaltabernacle Hello! It might be an MTU size issue. By default, on Linux and FreeBSD, WireGuard might set a 1420 bytes MTU size, which is too big for some networks. Shrink it to 1320 or even 1280 bytes (the minimum accepted value) and test again. In order to change wg interface MTU size on your BSD system, please edit the wg configuration file with any text editor and add the line: MTU = 1320 in the [Interface] section. Kind regards 4 nocturnaltabernacle, Wolf666, Air4141841 and 1 other reacted to this Quote Share this post Link to post
nocturnaltabernacle 2 Posted ... Thanks for the tip, that was indeed it. I found other discussion in the pfSense forums about it and they suggested MSS value of 1420 for the WG interface. Either setting will probably work just as well. Quote Share this post Link to post
go558a83nk 383 Posted ... 15 hours ago, nocturnaltabernacle said: I'm seeing some web pages not working through Wireguard while they work through OpenVPN on the same server. For example Firefox status bar might say "Performing a TLS handshake..." and the page loads without images and styles, or the page doesn't load at all. I'm running pfSense 2.6.0 as my router and AirVPN client and I tested from Linux and Mac workstations. What might be the issue? Go into the wireguard interface that you created and change MTU and MSS to 1420 or some other matching lower value but for me 1420 is fastest. 2 nocturnaltabernacle and Lee47 reacted to this Quote Share this post Link to post
nocturnaltabernacle 2 Posted ... 1 hour ago, go558a83nk said: Go into the wireguard interface that you created and change MTU and MSS to 1420 or some other matching lower value but for me 1420 is fastest. Thanks, I added 1420 to MSS and that seems to have fixed it and speed is good. Quote Share this post Link to post
