jdubau55
Need help with DDWRT x86 setup
Heres my OpenVPN log.
Serverlog Clientlog 20121119 22:32:30 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20121119 22:32:30 I LZO compression initialized
20121119 22:32:30 Control Channel MTU parms [ L:1572 D:140 EF:40 EB:0 ET:0 EL:0 ]
20121119 22:32:30 Socket Buffers: R=[87380->131072] S=[16384->131072]
20121119 22:32:30 Data Channel MTU parms [ L:1572 D:1450 EF:72 EB:135 ET:0 EL:0 AF:3/1 ]
20121119 22:32:30 Local Options String: 'V4 dev-type tun link-mtu 1572 tun-mtu 1500 proto TCPv4_CLIENT comp-lzo cipher AES-256-CBC auth SHA256 keysize 256 key-method 2 tls-client'
20121119 22:32:30 Expected Remote Options String: 'V4 dev-type tun link-mtu 1572 tun-mtu 1500 proto TCPv4_SERVER comp-lzo cipher AES-256-CBC auth SHA256 keysize 256 key-method 2 tls-server'
20121119 22:32:30 Local Options hash (VER=V4): '2ba0d2f5'
20121119 22:32:30 Expected Remote Options hash (VER=V4): '372232dd'
20121119 22:32:30 I Attempting to establish TCP connection with 198.15.111.162:80 [nonblock]
20121119 22:32:32 I TCP connection established with 198.15.111.162:80
20121119 22:32:32 I TCPv4_CLIENT link local: [undef]
20121119 22:32:32 I TCPv4_CLIENT link remote: 198.15.111.162:80
20121119 22:32:32 TLS: Initial packet from 198.15.111.162:80 sid=543413c4 379db085
20121119 22:32:33 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121119 22:32:33 VERIFY OK: nsCertType=SERVER
20121119 22:32:33 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121119 22:32:35 N Connection reset restarting [0]
20121119 22:32:35 TCP/UDP: Closing socket
20121119 22:32:35 I SIGUSR1[soft connection-reset] received process restarting
20121119 22:32:35 Restart pause 5 second(s)
20121119 22:32:40 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20121119 22:32:40 I Re-using SSL/TLS context
20121119 22:32:40 I LZO compression initialized
20121119 22:32:40 Control Channel MTU parms [ L:1572 D:140 EF:40 EB:0 ET:0 EL:0 ]
20121119 22:32:40 Socket Buffers: R=[87380->131072] S=[16384->131072]
20121119 22:32:40 Data Channel MTU parms [ L:1572 D:1450 EF:72 EB:135 ET:0 EL:0 AF:3/1 ]
20121119 22:32:40 Local Options String: 'V4 dev-type tun link-mtu 1572 tun-mtu 1500 proto TCPv4_CLIENT comp-lzo cipher AES-256-CBC auth SHA256 keysize 256 key-method 2 tls-client'
20121119 22:32:40 Expected Remote Options String: 'V4 dev-type tun link-mtu 1572 tun-mtu 1500 proto TCPv4_SERVER comp-lzo cipher AES-256-CBC auth SHA256 keysize 256 key-method 2 tls-server'
20121119 22:32:40 Local Options hash (VER=V4): '2ba0d2f5'
20121119 22:32:40 Expected Remote Options hash (VER=V4): '372232dd'
20121119 22:32:40 I Attempting to establish TCP connection with 198.15.111.162:80 [nonblock]
20121119 22:32:41 I TCP connection established with 198.15.111.162:80
20121119 22:32:41 I TCPv4_CLIENT link local: [undef]
20121119 22:32:41 I TCPv4_CLIENT link remote: 198.15.111.162:80
20121119 22:32:41 TLS: Initial packet from 198.15.111.162:80 sid=0c4ab83d 007182df
20121119 22:32:42 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121119 22:32:42 VERIFY OK: nsCertType=SERVER
20121119 22:32:42 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121119 22:32:43 MANAGEMENT: Client connected from 127.0.0.1:5001
20121119 22:32:43 D MANAGEMENT: CMD 'state'
20121119 22:32:43 MANAGEMENT: Client disconnected
20121119 22:32:43 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
