ChehTan 1 Posted ... Hello there, I currently have a specific setup : I have a Docker container creating the VPN connection to AirVPN. I have another Docker container for qBitTorrent that uses CT VPN's network to access internet (so the docker is always behind the VPN). I enabled Port Forwarding into AirVPN, and then configured such port into qBitTorrent to use it. But when I use the Test open button in AirVPN, only the IPv6 connection says Open. The IPv4 says Connection timed out. The fact that IPv6 says Open tells me that I correctly configured qBitTorrent and it should be working fine. However, with IPv4 timing out, qBitTorrent seems to not be seeding properly. Is there anything wrong with my set-up, or is this problem AirVPN related? Thank you in advance for you answer, I can provide any config file if necessary. Regards, Share this post Link to post
Tech Jedi Alex 1524 Posted ... Definitely not AirVPN-related. Post your docker-compose.yml or other relevant configs; it's possible something v4-specific is misconfigured. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
ChehTan 1 Posted ... (edited) Hello there ! I assumed that ^^ Here is my docker-compose.yml: The custom openvpn-client (on a private repo) is just to make openvpn compatible with Alpine 3 version: '3.8' services: vpn: container_name: openVPN image: conservat.vwa.re/groupvware/docker/openvpn-client:latest #dperson/openvpn-client:latest cap_add: - net_admin # required to modify network interfaces restart: unless-stopped networks: vpn_net: aliases: - vpn-bit labels: - autoheal=true ports: - 8081:8081 # port for qbitTorrent environment: - PUID=${PUID} - PGID=${PGID} - TZ=${TZ} devices: - /dev/net/tun:/dev/net/tun volumes: - /host/path/vpn:/vpn # OpenVPN configuration security_opt: - label:disable dns: - 9.9.9.9 sysctls: - net.ipv6.conf.all.disable_ipv6=0 command: '-f "" -r 192.168.1.0/24' qBittorrent: container_name: qBittorrent image: linuxserver/qbittorrent restart: unless-stopped labels: - autoheal=true network_mode: service:vpn # run on the VPN network volumes: - /host/path/qbittorrent:/config - /host/path/torrent_downloads:/downloads - /host/path/torrent_watchdog:/watchdog environment: - PUID=${PUID} - PGID=${PGID} - TZ=${TZ} - UMASK=022 - WEBUI_PORT=8081 healthcheck: test: ["CMD-SHELL", "curl --fail http://127.0.0.1:8081/api/v2/app/version || exit 1"] interval: 1m30s timeout: 10s retries: 3 start_period: 10s AirVPN allowed me the port 16400, which have been configured into qBitTorrent. Edited ... by ChehTan Share this post Link to post
Tech Jedi Alex 1524 Posted ... Does this qB container come with a GUI or WebUI only? Its log would be interesting to look at. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
ChehTan 1 Posted ... (edited) It seems to only have a WebGUI. I've found the logs, which tells me it successfully listened on all IPs it has, on the port 16400 on both TCP and uTP. I'll add them later tonight Edited ... by ChehTan Share this post Link to post
Tech Jedi Alex 1524 Posted ... 30 minutes ago, ChehTan said: and uTP Disable that, while you're at it. It conflicts with VPNs. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
ChehTan 1 Posted ... Hello ! Here is the logs that I have when qB starts:qbittorrent.log Share this post Link to post
ChehTan 1 Posted ... Okay, I finally found the issue: My OpenVPN container had an iptables configured that was dropping everthing. Using the regular iptables -t filter -A INPUT -p tcp --dport <MyForwardedPort> -j ACCEPT solved the issue Share this post Link to post
Tech Jedi Alex 1524 Posted ... The necessity to use iptables in such a container setup is one of those tidbits making troubleshooting difficult for those not familar with such setups. Personally, I thought you simply boot up the container and you're good to go, there was no mention of iptables being deployed anywhere. I'm glad you solved it, and even more glad that you came back and provided your solution; I thank you very much on behalf of the future. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
ChehTan 1 Posted ... I agree. And to me, since each Container is in a private IP network, having a firewall above this setup is a non-sense. You have your Router's firewall, your Host's firewall (for Docker's NAT/PAT system) and an in-container firewall? I know there's not too much security but here, it make things really complex for nothing... And I'm glad to provide the solution, because I've found myself many time reading a « It found the issue », with no solution given at all... Share this post Link to post
ChehTan 1 Posted ... Small update: If anyone is using the same source image as me, in order to have qBitTorrent to work properly, you must add the environment variable VPNPORT with your Port Forwarded from AirVPN Client Area, like so : vpn: container_name: openVPN image: conservat.vwa.re/groupvware/docker/openvpn-client:latest #dperson/openvpn-client:latest cap_add: - net_admin # required to modify network interfaces restart: unless-stopped networks: vpn_net: aliases: - vpn-bit labels: - autoheal=true ports: - 8081:8081 # port for qbitTorrent environment: - PUID=${PUID} - PGID=${PGID} - TZ=${TZ} - VPNPORT=<VPNPORTFROMAIR> # This one is TCP - VPNPORT_1=<VPNPORTFROMAIR>;udp devices: - /dev/net/tun:/dev/net/tun volumes: - /host/path/vpn:/vpn # OpenVPN configuration security_opt: - label:disable dns: - 9.9.9.9 sysctls: - net.ipv6.conf.all.disable_ipv6=0 command: '-f "" -r 192.168.1.0/24' 1 Stalinium reacted to this Share this post Link to post
