ddrahos
Specify a connection to only servers in Toronto?
Hi there, I'm in Toronto, Canada and I'm wondering if there's a way to specify that a connection to the Canada DNS, ca3.ipv6.vpn.airdns.org so it only connects to a Toronto server?
Alternatively is there a way to blacklist in my config any connections to the Vancouver and Montreal servers?
It's just annoying when it picks out Vancouver for a connection which is far away but on the flip side I would like to avoid being on one server in Toronto all the time in case it gets slammed by traffic. I'd like to even out the server load.
Any help is appreciated.
There is no direct way to do so, but you can filter it out indirectly by using the AV remotes webapp from a community member.Select Canada, then Toronto. Take note of the listed server names and configure your client to include them only.
