FlyawayRavage 0 Posted ... EDIT: Figured it out. I was under the assumption that systemd-resolved took over all DNS processing and made /etc/resolv.conf obsolete, but apparently that's still where AirVPN pushes the DNS settings too and somehow systemd-resolved overwrites it. Disabling systemd-resolved seems to have fixed this problem for now. Running AirVPNsuite on my server (Operating System: Debian GNU/Linux 11 (bullseye); Kernel: Linux 5.10.0-20-amd64), DNS breaks randomly 5-60mins after establishing connection. DNS settings, as far as I can tell, aren't being changed. I can still ping the server-pushed DNS server as well, but it just doesn't resolve. Relevant logs below: Logs immediately after establishing connection: root@labserver:~# resolvectl Global Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported resolv.conf mode: foreign Current DNS Server: 10.32.178.1 DNS Servers: 10.32.178.1 Link 2 (enp0s25) Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 Protocols: -DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported DNS Servers: 10.32.178.1 Link 3 (docker0) Current Scopes: none Protocols: -DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported DNS Servers: 10.32.178.1 Link 4 (tun0) Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 Protocols: +DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported DNS Servers: 10.32.178.1 root@labserver:~# goldcrest --bluetit-status 2023-03-02 22:47:43 Reading run control directives from file /root/.config/goldcrest.rc Goldcrest 1.2.1 - 9 December 2022 2023-03-02 22:47:43 Bluetit - AirVPN OpenVPN 3 Service 1.2.1 - 9 December 2022 2023-03-02 22:47:43 OpenVPN core 3.8.2 AirVPN linux x86_64 64-bit 2023-03-02 22:47:43 Copyright (C) 2012-2020 OpenVPN Inc. All rights reserved. 2023-03-02 22:47:43 OpenSSL 1.1.1n 15 Mar 2022 2023-03-02 22:47:43 Bluetit is connected to VPN 2023-03-02 22:47:43 Persistent Network Lock and Filter is enabled. (using nftables) 2023-03-02 22:47:43 ---------------------- 2023-03-02 22:47:43 Connected to AirVPN server Yildun (Miami, United States of America) 2023-03-02 22:47:43 Users 50 - Load 8% - Bandwidth 80.08 Mbit/s - Max 1 Gbit/s 2023-03-02 22:47:43 Server IP Address 173.44.55.181 - Port 443 - Protocol UDPv4 - Cipher AES-256-GCM 2023-03-02 22:47:43 Network topology: subnet - Server ping 10 s - Ping restart 60 s 2023-03-02 22:47:43 Pushed DNS: 10.32.178.1 (IPv4) 2023-03-02 22:47:43 Connection time: 00:02:25 2023-03-02 22:47:43 Transferred data: In 34.09 KB, Out 9.15 KB 2023-03-02 22:47:43 Current rate: In 0 bit/s, Out 0 bit/s 2023-03-02 22:47:43 Maximum rate: In 14.78 Kbit/s, Out 1.09 Kbit/s root@labserver:~# ping google.com PING google.com (142.250.217.206) 56(84) bytes of data. 64 bytes from mia07s61-in-f14.1e100.net (142.250.217.206): icmp_seq=1 ttl=120 time=72.3 ms 64 bytes from mia07s61-in-f14.1e100.net (142.250.217.206): icmp_seq=2 ttl=120 time=72.3 ms 64 bytes from mia07s61-in-f14.1e100.net (142.250.217.206): icmp_seq=3 ttl=120 time=72.5 ms Logs ~1 hour later when DNS has failed: root@labserver:~# resolvectl Global Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported resolv.conf mode: foreign Current DNS Server: 10.32.178.1 DNS Servers: 10.32.178.1 Link 2 (enp0s25) Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 Protocols: -DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported DNS Servers: 10.32.178.1 Link 3 (docker0) Current Scopes: none Protocols: -DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported DNS Servers: 10.32.178.1 Link 4 (tun0) Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 Protocols: +DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported DNS Servers: 10.32.178.1 root@labserver:~# goldcrest --bluetit-status 2023-03-02 23:56:38 Reading run control directives from file /root/.config/goldcrest.rc Goldcrest 1.2.1 - 9 December 2022 2023-03-02 23:56:38 Bluetit - AirVPN OpenVPN 3 Service 1.2.1 - 9 December 2022 2023-03-02 23:56:38 OpenVPN core 3.8.2 AirVPN linux x86_64 64-bit 2023-03-02 23:56:38 Copyright (C) 2012-2020 OpenVPN Inc. All rights reserved. 2023-03-02 23:56:38 OpenSSL 1.1.1n 15 Mar 2022 2023-03-02 23:56:38 Bluetit is connected to VPN 2023-03-02 23:56:38 Persistent Network Lock and Filter is enabled. (using nftables) 2023-03-02 23:56:39 ---------------------- 2023-03-02 23:56:39 Connected to AirVPN server Yildun (Miami, United States of America) 2023-03-02 23:56:39 Users 50 - Load 4% - Bandwidth 48.70 Mbit/s - Max 1 Gbit/s 2023-03-02 23:56:39 Server IP Address 173.44.55.181 - Port 443 - Protocol UDPv4 - Cipher AES-256-GCM 2023-03-02 23:56:39 Network topology: subnet - Server ping 10 s - Ping restart 60 s 2023-03-02 23:56:39 Pushed DNS: 10.32.178.1 (IPv4) 2023-03-02 23:56:39 Connection time: 01:11:19 2023-03-02 23:56:39 Transferred data: In 627.65 KB, Out 107.48 KB 2023-03-02 23:56:39 Current rate: In 20 bit/s, Out 0 bit/s 2023-03-02 23:56:39 Maximum rate: In 65.65 Kbit/s, Out 3.59 Kbit/s root@labserver:~# ping google.com ping: google.com: Temporary failure in name resolution root@labserver:~# ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=120 time=72.3 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=120 time=72.3 ms 64 bytes from 8.8.8.8: icmp_seq=3 ttl=120 time=72.3 ms root@labserver:~# dig google.com ; <<>> DiG 9.16.33-Debian <<>> google.com ;; global options: +cmd ;; connection timed out; no servers could be reached Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 3 hours ago, FlyawayRavage said: EDIT: Figured it out. I was under the assumption that systemd-resolved took over all DNS processing and made /etc/resolv.conf obsolete, but apparently that's still where AirVPN pushes the DNS settings too and somehow systemd-resolved overwrites it. Disabling systemd-resolved seems to have fixed this problem for now. It's not so much an override as it is a symlink to a legacy resolv.conf managed by resolved, and it checks from time to time whether the resolv.conf is still a symlink, of course, hence the "every 5-60 minutes it fails". But, glad you resolved it. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
