Affenkopf 0 Posted ... Hi everyone, i want to use the Wireguard Protocol from AirVPN on a Openwrt Router behind my ISP Router. Is there any Guide for this solution? I found many Guides from other VPN Services but it doesn't work for me. Can anybody help me with this problem? Quote Share this post Link to post
Staff 10421 Posted ... Hello! The proper guide is this one: https://openwrt.org/docs/guide-user/services/vpn/wireguard/client Keep a profile generated by the Configuration Generator, according to your preferences, available (it's just a text file). From it, you can find the settings for the initial configuration: WG_IF="vpn" WG_SERV="SERVER_ADDRESS" <-- the VPN server address you see in the "Endpoint" entry WG_PORT="1637" <-- you can see it in the "Endpoint" entry WG_ADDR="..." <-- the IPv4 address you find in the profile "Address" entry WG_ADDR6="..." <-- the IPv6 address you find in the profile "Address" entry Skip the "Key management" section. In our system your WireGuard key is generated by our infrastructure. In the same file you also find the public key, the pre-shared key and the DNS server address that you will need to complete the configuration, respectively in the PublicKey entry, the PresharedKey entry and the DNS entry. Kind regards Quote Share this post Link to post
francisuk1989 0 Posted ... If your familiar with nano under SSH or WInscp? You can edit the follow files. 1st` On 2/15/2023 at 9:43 AM, Staff said: Keep a profile generated by the Configuration Generator, according to your preferences, available (it's just a text file). From it, you can find the settings for the initial configuration: then nano /etc/config/network config interface 'vpn' option proto 'wireguard' list addresses 'YOUR Address found in .conf file' option private_key 'PrivateKey' config wireguard_vpn option public_key 'PublicKey' option preshared_key 'PresharedKey' list allowed_ips '0.0.0.0/0' option endpoint_host 'AIRVPN SERVER IP found in .conf file' option endpoint_port '1637' option persistent_keepalive '15' option description 'AirVPN' config device option name 'vpn' option multicast '0' Quote Share this post Link to post
DawnTurnage 1 Posted ... (edited) On 2/15/2023 at 2:12 PM, Affenkopf said: Hi everyone, i want to use the Wireguard Protocol from AirVPN on a Openwrt Router behind my ISP Router. Is there any Guide for this solution? I found many Guides from other VPN Services but it doesn't work for me. Can anybody help me with this problem? Have you found the guide? Edited ... by DawnTurnage Quote Share this post Link to post
