Hey there,
I'm trying to setup two wiregaurd peers on pfsense.
Either alone works fine, but I can't get them both to work. My problem seems to be that the config for either peer is identical other than the endpoint address.
If I use one tunnel and two peers pfsense complains that the keys are already in use, if I create two tunnels, pfsense complains that the IP address (given in the interface as address in the conf file) is already in use.
Any help is greatly appreciated!
-Toby
8 hours ago, TobyWan said:
Hey there,
-Toby
Do you happen to have a tutorial on how to set up WireGuard on PfSense 2.6?
I am thinking of getting started with it as well since my speed dropped considerably when I upgraded to the newest version of pfSense a while back.
Please, let me know.
well, back when wireguard first came out as a package for pfsense I happened upon a youtube video from, I think, the guy who made the wireguard package while browsing the pfsense subreddit.  but now when I search it's difficult to find that particular video.  Sorry I can't be more help.
14 hours ago, go558a83nk said:
you need to use your devices page to make another device.  download a new config for that new device.  then when setting up the interface you'll need to change the net mask to /32 so that the two devices don't overlap IP range.
https://airvpn.org/devices/
Thank you very much!
I don't have a particular tutorial. at the week I'll setup a new tunnel, if I have enough time, I can take some screenshots.
It would be greatly helpful if you do that for me and possibly others.
Thanks.
Watch Christian's tutorials and backgrond infomation on the WG project. The guy is top level!
https://www.youtube.com/channel/UCDy7UMGSzG0qgnRskSx62DQ
