squidf
Eddie-ui: no tray icon
Hi
I just packaged Eddie-ui for Mageia Linux and it works very well with Wireguard protocol. There are other posts discussing the issues with openVPN.
One more issue is the lack of tray icons, despite I have selected "Minimize in tray" in the Menu. It is the same behavior between Eddie 2.21.8 and 2.22.2.
Same issue under Plasma 5.20.4 and 5.26.4, and Cinnamon 4.8.3
When I launch eddie-ui from a terminal, I get the following messages:
/usr/lib64/eddie-ui/eddie-tray: /usr/lib64/eddie-ui/eddie-tray: no version information available (required by /usr/lib64/eddie-ui/eddie-tray)
/usr/lib64/eddie-ui/eddie-tray: symbol lookup error: /usr/lib64/eddie-ui/eddie-tray: undefined symbol: , version
Could it be related? Could it be something is missing when I build it? Or a dependence?
Thanks!
13 hours ago, OpenSourcerer said:
Is libayatana-appindicator installed?
Hi. Yes it is.
$ rpm -qa *ayatana*
lib64ayatana-indicator3_7-0.8.3-1.mga8
lib64ayatana-ido3_0.4_0-0.8.1-1.mga8
lib64ayatana-appindicator3_1-0.5.5-6.mga8
lib64ayatanaappindicator3-gir0.1-0.5.5-6.mga8
Do these packages include headers for building? There are numerous distributions where development headers must be installed separately; not sure about Mageia here.
Hi. -devel package is used as a build dependency, indeed. The packages listed above are the ones installed as installation dependencies, required by Eddie when installing.
-devel packages with the headers are usually not required when the package is already built. I will test with it though to make sure.
