petes58956jfd
ANSWERED Dual (2) Wireguard Tunnels - How to get different IP address
So I am using PfSense and I am trying to setup 2 Wireguard tunnels (2 Different Servers) so I can do load balancing+failover
but.... I get assigned the exact same "Your VPN IPv4:" IP address 10.x.x.x .
Does anyone have any ideas on How can I get this working with 2 different interface+tunnels?
Solved: AirVPN support informed me there was a "Device" section under "Client Area".
You Create a 2nd device, and then under "Config Generator" under the Ports is a section to select which Device.
"Yes, you must generate profiles with two different keys. See here:
https://airvpn.org/forums/topic/26209-how-to-manage-client-certificatekey-pairs/
In this way you will be assigned different IP addresses for each key."
