The_Purist 1 Posted ... Hi This happens everytime on boot with Windows 10. Eddie just hangs and won't finishing loading until I go into task manager and close the OpenVPN service. At that point Eddie completes loading and connects normally. Any ideas? Quote Share this post Link to post
Staff 10379 Posted ... @The_Purist Hello! Thanks, Eddie should not hang if the OpenVPN service is already running, it should warn you and only then exit. Probably it's a matter for developer's investigation. In the meantime you should be able to resolve the problem instantly by avoiding to start the OpenVPN service. Eddie manages either WireGuard or OpenVPN according to your preferences, so another OpenVPN or WireGuard instance already running will create conflicts. Kind regards Quote Share this post Link to post
