Hi. I´m new airVPN user and I just downloaded it. I dissabled Firewall entirely alongside with my AV and ran edie as an admin. When I click on recommended server connection it connects to server, disconnects, try to reconnect and the round go again the same. I looked at logs and the loop always end with message ,,Authorization failed. Look at the client area to discover the reason.,, I looked in client area and IDK what should I find there. I´m dropping Log under message.
I 2022.12.01 10:33:22 - Session starting.
I 2022.12.01 10:33:22 - Checking authorization ...
. 2022.12.01 10:33:23 - Using WinTun network interface "wintunshark0 (Surfshark Tunnel)"
! 2022.12.01 10:33:23 - Connecting to Phaet (Netherlands, Alblasserdam)
. 2022.12.01 10:33:23 - Routes, add .................................. (I don´t wanna post my IP here) for interface "Ethernet (Realtek PCIe GbE Family Controller)".
. 2022.12.01 10:33:23 - Routes, add ................................. (I don´t wanna post my IP here) for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists.
. 2022.12.01 10:33:23 - Routes, add ................................. (I don´t wanna post my IP here) for interface "Ethernet (Realtek PCIe GbE Family Controller)".
. 2022.12.01 10:33:23 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2022.12.01 10:33:23 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.12.01 10:33:23 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2022.12.01 10:33:23 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.12.01 10:33:23 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.12.01 10:33:23 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.12.01 10:33:23 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.12.01 10:33:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.187.232:443
. 2022.12.01 10:33:23 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.12.01 10:33:23 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.187.232:443 [nonblock]
. 2022.12.01 10:33:23 - OpenVPN > TCP connection established with [AF_INET]213.152.187.232:443
. 2022.12.01 10:33:23 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2022.12.01 10:33:23 - OpenVPN > TCP_CLIENT link remote: [AF_INET]213.152.187.232:443
. 2022.12.01 10:33:23 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.187.232:443, sid=f18dda83 a093043a
. 2022.12.01 10:33:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.12.01 10:33:23 - OpenVPN > VERIFY KU OK
. 2022.12.01 10:33:23 - OpenVPN > Validating certificate extended key usage
. 2022.12.01 10:33:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.12.01 10:33:23 - OpenVPN > VERIFY EKU OK
. 2022.12.01 10:33:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Phaet, emailAddress=info@airvpn.org
. 2022.12.01 10:33:23 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2022.12.01 10:33:23 - OpenVPN > [Phaet] Peer Connection Initiated with [AF_INET]213.152.187.232:443
. 2022.12.01 10:33:24 - OpenVPN > SENT CONTROL [Phaet]: 'PUSH_REQUEST' (status=1)
. 2022.12.01 10:33:24 - OpenVPN > AUTH: Received control message: AUTH_FAILED
W 2022.12.01 10:33:24 - Authorization failed. Look at the client area to discover the reason.
. 2022.12.01 10:33:24 - OpenVPN > SIGTERM[soft,auth-failure] received, process exiting
! 2022.12.01 10:33:24 - Disconnecting
Edited ... by Sparkly Star
