Dorn64 0 Posted ... For anyone interested in how to setup AirVPN in Linux with NetworkManager on the command line. Create connection Get WireGuard Config File from AirVPN website: https://airvpn.org/generator Name Config File to wg0.conf Import Config File: sudo nmcli connection import type wireguard file wg0.conf View connections: nmcli connection show Rename connection: nmcli connection modify wg0 connection.id "MyConnection" Manage connection Start VPN Connection: nmcli connection up "MyConnection" Stop VPN Connection: nmcli connection down "MyConnection" Check IP visit https://ipleak.net/ Check VPN connection: nmcli connection show --active | grep "MyConnection" Interesting commands Check IP interface: ip a show wg0 nmcli manual page: man nmcli Notes tested on ArchLinux 6.0.9-arch1-1 i tried OpenVPN with NetworkManager first, IPv4 worked but IPv6 didn't, apparently due to a missing feature in networkmanager-openvpn Have a nice day Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... Can confirm it working – if imported using the command line, that is. If you use the GUI to import that, it won't work. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
salvialight 0 Posted ... is this doable on pi OS? i'm totally novice with this stuff. not sure when to input these commands. i have the airVPN wireguard conf file. i don't understand how/when to use the nmcli commands. i'm only doing this because the eddie GUI client just freezes upon launch no matter what i do (even on a fresh install of pi os) Quote Share this post Link to post
Staff 10486 Posted ... 8 hours ago, salvialight said: is this doable on pi OS? i'm totally novice with this stuff. not sure when to input these commands. i have the airVPN wireguard conf file. i don't understand how/when to use the nmcli commands. i'm only doing this because the eddie GUI client just freezes upon launch no matter what i do (even on a fresh install of pi os) Hello! In this case you had better go directly with wg-quick and not nmcli. https://airvpn.org/linux/wireguard/terminal/ Kind regards Quote Share this post Link to post
