billdevices
AirVPN Tor Clarification?
Do your direction support local to vpn to tor, or do your directions create local to tor to vpn?
The following instructions show you how to connect over AirVPN over TOR:
https://airvpn.org/tor
In the above case all the programs will be tunneled over OpenVPN over TOR, leaving open the option to additionally add another tunnel (proxy over Air over TOR, TOR over Air over TOR, VPN over Air over TOR etc. etc.).
In order instead to connect over TOR over AirVPN: first connect to an Air server, then launch TOR. In this case only the programs that are configured to tunnel over TOR will be tunneled over TOR over OpenVPN. The programs not using TOR will be tunneled over OpenVPN alone.
