Droopy 2 Posted ... 65417 26.232188000 95.211.149.200 192.---.-.- IPv4 71 Fragmented IP protocol (proto=UDP 17, off=1480, ID=6eac) [Reassembled in #65419]65418 26.232464000 95.211.149.200 192.---.-.- IPv4 1506 Fragmented IP protocol (proto=UDP 17, off=0, ID=6eac) [Reassembled in #65419] Wireshark is showing the above, last night the VPN dropped out could this be the cause, below is Air VPN logs, I have reinstalled windows. 9/11/2012 - 12:19 AM Replay-window backtrack occurred [4] 9/11/2012 - 12:19 AM Replay-window backtrack occurred [5] 9/11/2012 - 12:19 AM Replay-window backtrack occurred [6] 9/11/2012 - 12:19 AM Replay-window backtrack occurred [7] 9/11/2012 - 12:28 AM [server] Inactivity timeout (--ping-restart), restarting 9/11/2012 - 12:28 AM TCP/UDP: Closing socket 9/11/2012 - 12:28 AM Re-connecting... 9/11/2012 - 12:28 AM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.0.141 9/11/2012 - 12:28 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 12:28 AM C:\WINDOWS\system32\route.exe DELETE 95.211.149.200 MASK 255.255.255.255 192.168.0.1 9/11/2012 - 12:28 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 12:28 AM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.141 9/11/2012 - 12:28 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 12:28 AM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.141 9/11/2012 - 12:28 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 12:28 AM Closing TUN/TAP interface 9/11/2012 - 12:28 AM SIGUSR1[soft,ping-restart] received, process restarting 9/11/2012 - 12:28 AM Restart pause, 2 second(s) 9/11/2012 - 12:28 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/11/2012 - 12:28 AM LZO compression initialized 9/11/2012 - 12:28 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/11/2012 - 12:28 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/11/2012 - 12:28 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/11/2012 - 12:28 AM Local Options hash (VER=V4): '22188c5b' 9/11/2012 - 12:28 AM Expected Remote Options hash (VER=V4): 'a8f55717' 9/11/2012 - 12:28 AM UDPv4 link local: [undef] 9/11/2012 - 12:28 AM UDPv4 link remote: 95.211.149.200:443 9/11/2012 - 12:28 AM TLS: Initial packet from 95.211.149.200:443, sid=2d47c809 03a6f51f 9/11/2012 - 12:28 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 9/11/2012 - 12:28 AM VERIFY OK: nsCertType=SERVER 9/11/2012 - 12:28 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 9/11/2012 - 12:28 AM Failed to start. 9/11/2012 - 12:31 AM Login... 9/11/2012 - 12:31 AM Login success. 9/11/2012 - 12:31 AM Contacting service... 9/11/2012 - 12:31 AM Connecting... 9/11/2012 - 12:31 AM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 9/11/2012 - 12:31 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/11/2012 - 12:31 AM LZO compression initialized 9/11/2012 - 12:31 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/11/2012 - 12:31 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/11/2012 - 12:31 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/11/2012 - 12:31 AM Local Options hash (VER=V4): '22188c5b' 9/11/2012 - 12:31 AM Expected Remote Options hash (VER=V4): 'a8f55717' 9/11/2012 - 12:31 AM UDPv4 link local: [undef] 9/11/2012 - 12:31 AM UDPv4 link remote: 109.163.230.232:443 9/11/2012 - 12:31 AM TLS: Initial packet from 109.163.230.232:443, sid=13597267 2525a089 9/11/2012 - 12:32 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 9/11/2012 - 12:32 AM VERIFY OK: nsCertType=SERVER 9/11/2012 - 12:32 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 9/11/2012 - 12:32 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/11/2012 - 12:32 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/11/2012 - 12:32 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/11/2012 - 12:32 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/11/2012 - 12:32 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 9/11/2012 - 12:32 AM [server] Peer Connection Initiated with 109.163.230.232:443 9/11/2012 - 12:32 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/11/2012 - 12:32 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.0.194 10.4.0.193' 9/11/2012 - 12:32 AM OPTIONS IMPORT: timers and/or timeouts modified 9/11/2012 - 12:32 AM OPTIONS IMPORT: LZO parms modified 9/11/2012 - 12:32 AM OPTIONS IMPORT: --ifconfig/up options modified 9/11/2012 - 12:32 AM OPTIONS IMPORT: route options modified 9/11/2012 - 12:32 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 9/11/2012 - 12:32 AM ROUTE default_gateway=192.168.0.1 9/11/2012 - 12:32 AM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{DABE0A8D-C938-4456-821B-5DDE14B89234}.tap 9/11/2012 - 12:32 AM TAP-Win32 Driver Version 9.9 9/11/2012 - 12:32 AM TAP-Win32 MTU=1500 9/11/2012 - 12:32 AM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.0.194/255.255.255.252 on interface {DABE0A8D-C938-4456-821B-5DDE14B89234} [DHCP-serv: 10.4.0.193, lease-time: 31536000] 9/11/2012 - 12:32 AM Successful ARP Flush on interface [14] {DABE0A8D-C938-4456-821B-5DDE14B89234} 9/11/2012 - 12:32 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 9/11/2012 - 12:32 AM C:\WINDOWS\system32\route.exe ADD 109.163.230.232 MASK 255.255.255.255 192.168.0.1 9/11/2012 - 12:32 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 9/11/2012 - 12:32 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 12:32 AM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.193 9/11/2012 - 12:32 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 9/11/2012 - 12:32 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 12:32 AM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.193 9/11/2012 - 12:32 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 9/11/2012 - 12:32 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 12:32 AM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.0.193 9/11/2012 - 12:32 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 9/11/2012 - 12:32 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 12:32 AM Initialization Sequence Completed 9/11/2012 - 12:32 AM Starting Management Interface... 9/11/2012 - 12:32 AM Checking... 9/11/2012 - 12:32 AM Retrieve statistics... 9/11/2012 - 12:32 AM Connected. 9/11/2012 - 12:33 AM Replay-window backtrack occurred [1] 9/11/2012 - 12:33 AM Replay-window backtrack occurred [2] 9/11/2012 - 12:33 AM Replay-window backtrack occurred [4] 9/11/2012 - 12:36 AM Replay-window backtrack occurred [5] 9/11/2012 - 12:36 AM Replay-window backtrack occurred [6] 9/11/2012 - 12:48 AM Replay-window backtrack occurred [23] 9/11/2012 - 1:28 AM Replay-window backtrack occurred [37] 9/11/2012 - 1:29 AM Replay-window backtrack occurred [43] 9/11/2012 - 1:29 AM Replay-window backtrack occurred [56] 9/11/2012 - 1:32 AM TLS: soft reset sec=0 bytes=4679359176/0 pkts=5252683/0 9/11/2012 - 1:32 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 9/11/2012 - 1:32 AM VERIFY OK: nsCertType=SERVER 9/11/2012 - 1:32 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 9/11/2012 - 1:32 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/11/2012 - 1:32 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/11/2012 - 1:32 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/11/2012 - 1:32 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/11/2012 - 1:32 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 9/11/2012 - 1:42 AM [server] Inactivity timeout (--ping-restart), restarting 9/11/2012 - 1:42 AM TCP/UDP: Closing socket 9/11/2012 - 1:42 AM Re-connecting... 9/11/2012 - 1:42 AM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.0.193 9/11/2012 - 1:42 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 1:42 AM C:\WINDOWS\system32\route.exe DELETE 109.163.230.232 MASK 255.255.255.255 192.168.0.1 9/11/2012 - 1:42 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 1:42 AM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.193 9/11/2012 - 1:42 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 1:42 AM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.193 9/11/2012 - 1:42 AM Route deletion via IPAPI succeeded [adaptive] 9/11/2012 - 1:42 AM Closing TUN/TAP interface 9/11/2012 - 1:42 AM SIGUSR1[soft,ping-restart] received, process restarting 9/11/2012 - 1:42 AM Restart pause, 2 second(s) 9/11/2012 - 1:42 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/11/2012 - 1:42 AM LZO compression initialized 9/11/2012 - 1:42 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/11/2012 - 1:42 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/11/2012 - 1:42 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/11/2012 - 1:42 AM Local Options hash (VER=V4): '22188c5b' 9/11/2012 - 1:42 AM Expected Remote Options hash (VER=V4): 'a8f55717' 9/11/2012 - 1:42 AM UDPv4 link local: [undef] 9/11/2012 - 1:42 AM UDPv4 link remote: 109.163.230.232:443 9/11/2012 - 1:42 AM TLS: Initial packet from 109.163.230.232:443, sid=54b7b901 8aa765c5 9/11/2012 - 1:42 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 9/11/2012 - 1:42 AM VERIFY OK: nsCertType=SERVER 9/11/2012 - 1:42 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 9/11/2012 - 1:42 AM Failed to start. 9/11/2012 - 8:45 AM Login... 9/11/2012 - 8:45 AM Login success. 9/11/2012 - 8:45 AM Contacting service... 9/11/2012 - 8:45 AM Connecting... 9/11/2012 - 8:45 AM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 9/11/2012 - 8:45 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/11/2012 - 8:45 AM LZO compression initialized 9/11/2012 - 8:45 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/11/2012 - 8:45 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/11/2012 - 8:45 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/11/2012 - 8:45 AM Local Options hash (VER=V4): '22188c5b' 9/11/2012 - 8:45 AM Expected Remote Options hash (VER=V4): 'a8f55717' 9/11/2012 - 8:45 AM UDPv4 link local: [undef] 9/11/2012 - 8:45 AM UDPv4 link remote: 95.211.149.200:443 9/11/2012 - 8:45 AM TLS: Initial packet from 95.211.149.200:443, sid=b0adc615 574424cc 9/11/2012 - 8:45 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 9/11/2012 - 8:45 AM VERIFY OK: nsCertType=SERVER 9/11/2012 - 8:45 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 9/11/2012 - 8:45 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/11/2012 - 8:45 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/11/2012 - 8:45 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/11/2012 - 8:45 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/11/2012 - 8:45 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 9/11/2012 - 8:45 AM [server] Peer Connection Initiated with 95.211.149.200:443 9/11/2012 - 8:45 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/11/2012 - 8:45 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.0.142 10.4.0.141' 9/11/2012 - 8:45 AM OPTIONS IMPORT: timers and/or timeouts modified 9/11/2012 - 8:45 AM OPTIONS IMPORT: LZO parms modified 9/11/2012 - 8:45 AM OPTIONS IMPORT: --ifconfig/up options modified 9/11/2012 - 8:45 AM OPTIONS IMPORT: route options modified 9/11/2012 - 8:45 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 9/11/2012 - 8:45 AM ROUTE default_gateway=192.168.0.1 9/11/2012 - 8:45 AM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{DABE0A8D-C938-4456-821B-5DDE14B89234}.tap 9/11/2012 - 8:45 AM TAP-Win32 Driver Version 9.9 9/11/2012 - 8:45 AM TAP-Win32 MTU=1500 9/11/2012 - 8:45 AM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.0.142/255.255.255.252 on interface {DABE0A8D-C938-4456-821B-5DDE14B89234} [DHCP-serv: 10.4.0.141, lease-time: 31536000] 9/11/2012 - 8:45 AM Successful ARP Flush on interface [14] {DABE0A8D-C938-4456-821B-5DDE14B89234} 9/11/2012 - 8:46 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 9/11/2012 - 8:46 AM C:\WINDOWS\system32\route.exe ADD 95.211.149.200 MASK 255.255.255.255 192.168.0.1 9/11/2012 - 8:46 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 9/11/2012 - 8:46 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 8:46 AM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.141 9/11/2012 - 8:46 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 9/11/2012 - 8:46 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 8:46 AM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.141 9/11/2012 - 8:46 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 9/11/2012 - 8:46 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 8:46 AM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.0.141 9/11/2012 - 8:46 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 9/11/2012 - 8:46 AM Route addition via IPAPI succeeded [adaptive] 9/11/2012 - 8:46 AM Initialization Sequence Completed 9/11/2012 - 8:46 AM Starting Management Interface... 9/11/2012 - 8:46 AM Checking... 9/11/2012 - 8:46 AM Retrieve statistics... 9/11/2012 - 8:46 AM Connected. 9/11/2012 - 8:46 AM Replay-window backtrack occurred [1] 9/11/2012 - 8:46 AM Replay-window backtrack occurred [2] 9/11/2012 - 8:47 AM Replay-window backtrack occurred [3] 9/11/2012 - 8:47 AM Replay-window backtrack occurred [4] 9/11/2012 - 8:48 AM Replay-window backtrack occurred [6] 9/11/2012 - 8:48 AM Replay-window backtrack occurred [8] 9/11/2012 - 8:48 AM Replay-window backtrack occurred [9] 9/11/2012 - 8:48 AM Replay-window backtrack occurred [11] 9/11/2012 - 8:49 AM Replay-window backtrack occurred [12] 9/11/2012 - 8:53 AM Replay-window backtrack occurred [14] 9/11/2012 - 9:00 AM Replay-window backtrack occurred [19] Quote Share this post Link to post
Staff 10386 Posted ... 65417 26.232188000 95.211.149.200 192.---.-.- IPv4 71 Fragmented IP protocol (proto=UDP 17, off=1480, ID=6eac) [Reassembled in #65419]65418 26.232464000 95.211.149.200 192.---.-.- IPv4 1506 Fragmented IP protocol (proto=UDP 17, off=0, ID=6eac) [Reassembled in #65419]Wireshark is showing the above, last night the VPN dropped out could this be the cause, below is Air VPN logs, I have reinstalled windows.Hello!Yes, that can be the cause: the logs show a high packet loss. If the problem persists, please try a TCP connection, or tune your OpenVPN client, for example with mssfix. Please see here for details:https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=4853&limit=6&limitstart=12&Itemid=142#4957If you suffer significant performance loss with a TCP connection, then it's worth trying the above on an UDP connection. You can insert the directives directly in the .ovpn configuration file (anywhere). In this case you will have to use OpenVPN, not the Air client.Please feel free to keep us updated.Kind regards Quote Share this post Link to post
