steveo73
ANSWERED Connection Error via terminal
Hi - I am just getting the following error.
DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
I have updated my config with the following amendment --data-ciphers-fallback BF-CBC and the following error occurs:-
2022-11-06 13:19:32 OpenSSL: error:0A00018E:SSL routines::ca md too weak
2022-11-06 13:19:32 Cannot load inline certificate file
I'm not sure what the issue is but I suspect the config files need updating.
I have downloaded new config files.
Steve
I figured this one out. It wasn't that easy. I read some of the other posts on this forum that were having the same issue a while back via Eddie. Basically I had to regenerate my config files after updating the key within the client area. It works now.
