luxc0r0
Sharing my goldcrest terminal script (bash)
Good evening!
I've kept meaning to clean this up and improve it so that I could share it with people here, but since it's doing what I need it to, I haven't done any work so I might as well share what I came up with. It might be useful to someone trying to accomplish the same thing or use it as a starting point for something with potentially a lot more features.
The script is launched from outside a terminal; it opens a terminal and runs goldcrest inside of it; the terminal output is duplicated so that notifications can appear when certain strings are matched in the terminal output. Originally the terminal was iconified to the systray via kdocker but I found my approach to be buggy for kdocker so I just let my window manager deal with it now; the window is always retrievable in order to hit Control+C to disconnect.
It was designed for my use to do what I needed it to do, nothing more. Someone could find it handy. Sorry I never developed it further. It should be basically portable with minor modifications, i.e. the preferred terminal emulator, sounds, icons
#!/usr/bin/env bash
# Control interface with notification daemon for goldcrest.
# by luxc0r0 with help from ~rts/oarion7
# THANKS TO AIR VPN STAFF:
# https://airvpn.org/forums/topic/52600-bash-attempting-to-direct-output-of-goldcrest-to-named-pipe-in-script/
# The problem is related to tee when it processes buffered fast output (Goldcrest and Bluetit are very fast). See also: https://askubuntu.com/questions/639877/tee-doesnt-get-whole-output-from-the-pipe
# By changing the initial standard out stream to "unbuffered" you will resolve the problem. Example:
# stdbuf -o0 ./goldcrest --air-connect | tee /tmpfs/gc.log
# Designed to run from a launcher, i.e. without a parent terminal;
# a child terminal pops up automatically and runs main functions
# Output of goldcrest is duplicated into a pipe and filtered to
# notify-send. Terminal can then be hidden or minimized.
# User can restore terminal as needed; two pipes are used so that
# Ctrl+C can be run on goldcrest rather than the container script.
# TO DO: Kdocker has been disabled; occasionally it was duplicating
# processes and maxing out the CPU. Letting window manager take over
# handling the extraneous terminal window and calling it when needed
popup_terminal="st" #tested: st, xfce4-terminal
term_title="Goldcrest Interface"
systray_icon="$HOME/Icons/Mine/goldcrest.png"  #no longer used
notify_icon="$HOME/Icons/Mine/goldcrest_tr.png"
connect_sound="$HOME/Audio/scifisounds/PremiumBeat_0013_cursor_click_11.wav"
notify_timeout="10" #seconds
deps=( xdotool notify-send goldcrest $popup_terminal ) # kdocker and alltray not reliable anymore
for i in "${deps[@]}"; do command -v "$i" >/dev/null ||
{ notify-send "$0" "Dependency required: $i"; exit 1; }
done
tmp_dir='/mnt/ramdisk' ; [[ ! -e "$tmp_dir" ]] && tmp_dir='/tmp'
# naughty is my bash script connected to AwesomeWM API; in place by
# default for color theming; use regular notify-send if not present
notify() {
	"$HOME/scripts/./naughty" "$term_title" "$1" "$2" "$3" \
    "$notify_icon" "$notify_timeout" & 2>/dev/null
[[ ! -f "$HOME/scripts/./naughty" ]] && {
    notify() {
        notify-send "$term_title" "$1" -i "$notify_icon" \
        -t "$(( "$notify_timeout" * 1000 ))" & 2>/dev/null
popup_wrapper() {
    [[ "$popup_terminal" == "st" ]] && {
    setsid "$popup_terminal" -c GoldCrest -t "$term_title" -e bash -c "$0 --child; bash" ;
    return
    setsid "$popup_terminal" -T "$term_title" -e "bash -c \"$0 --child; bash\""
pipe="${tmp_dir}/.goldcrest_fifo1"
int="${tmp_dir}/.goldcrest_fifo2"
if [[ "$1" == "--child" ]] ; then
    [[ ! -e "$pipe" ]] && { mkfifo "$pipe"; }
    [[ ! -e "$int" ]] && { mkfifo "$int"; }
    #launch notification daemon if not already running
	[[ "$(ps -aux | grep "$0 --notif[y]")" ]] || { "$0" "--notify" & >/dev/null; }
    #minimize terminal to systray
    #kdocker -d -q -w "$(xdotool search --name "$term_title")" -i "$systray_icon" & >/dev/null
    #inconsistent results, consider other ways to do this
    tee -i "$pipe" < "$int" &
    stdbuf -o0 goldcrest --air-connect > "$int"
    #https://askubuntu.com/questions/639877/tee-doesnt-get-whole-output-from-the-pipe
    #https://airvpn.org/forums/topic/52600-bash-attempting-to-direct-output-of-goldcrest-to-named-pipe-in-script/
    echo "${0}: Exiting."
    sleep 2
elif [[ "$1" == "--notify" ]] ; then
    while read info
    do
        if echo "$info" | grep "Connected to AirVPN server" >/dev/null ; then
            [[ -z "$server" ]] && server=$(echo "$info" | sed 's/[0-9:\-]//g; s/^  //; s/United States of America/US/' )
            [[ -n "$server" ]] && [[ "$server" != "Done." ]] && notify "$server" "#FFB31E" "#000000"
            server="Done."
        elif echo "$info" | grep "EVENT: CONNECTING" >/dev/null ; then
            notify "Connecting..."
        elif echo "$info" | grep "EVENT: RECONNECTING" >/dev/null ; then
        elif echo "$info" | grep "EVENT: CONNECTED" >/dev/null ; then
            notify "Connected!" "#FFB31E" "#000000"
            [[ -f "$connect_sound" ]] && command -v paplay >/dev/null && paplay "$connect_sound" &
        elif echo "$info" | grep "EVENT: DISCONNECTED" >/dev/null ; then
            notify "Disconnected."
        fi
    done < "$pipe"
else
    popup_wrapper
fi
