Maggie144 12 Posted ... https://mullvad.net/en/blog/2022/10/10/android-leaks-connectivity-check-traffic/ is the reason for it. via adb adb shell settings put global captive_portal_mode 0 maybe someone with technical knowledge can enlighten us if it's still recommended with the new Eddie 3.0 Quote Share this post Link to post
Stalinium 54 Posted ... Confusing of mullvad to describe connectivity check when they mean captive portal check... I don't see how any Eddie version can fix Android's network checks. If Mullvad had a way with their app, they'd have fixed it. Quote Share this post Link to post
Staff 10433 Posted ... @Maggie144 Hello! Congratulations to Mullvad for this discovery and shame on Google. Some answers by Google personnel in the issue tracker https://issuetracker.google.com/issues/250529027 are embarrassing (to say the least...) and Mullvad replies are effective and clear. The issue must be taken seriously especially if you live in certain countries and the suggested solution via adb should be applied. It requires a computer and minimal knowledge, though. Kind regards Quote Share this post Link to post
