sableslayer
airvpn suite problems...
Ok so I have a rockpro64 running manjaro and using the arm64 binaries for the airvpn suite.
been configuring it, and cant seem to get it right, it will login and connect but for some reason  logout What am i doing wrong?
[xen@rockpro64 ~]$ sudo goldcrest --air-connect
[sudo] password for xen:
2022-10-02 23:52:31 Reading run control directives from file /root/.goldcrest.rc
Goldcrest 1.2.0 - 22 March 2022
2022-10-02 23:52:31 Bluetit - AirVPN OpenVPN 3 Service 1.2.0 - 22 March 2022
2022-10-02 23:52:31 OpenVPN core 3.8.1 AirVPN linux arm64 64-bit
2022-10-02 23:52:32 Copyright (C) 2012-2020 OpenVPN Inc. All rights reserved.
2022-10-02 23:52:32 OpenSSL 1.1.1q  5 Jul 2022
2022-10-02 23:52:32 Bluetit is ready
2022-10-02 23:52:32 Bluetit options successfully reset
2022-10-02 23:52:32 Bluetit successfully set to command line options
2022-10-02 23:52:32 Requesting AirVPN connection to Bluetit
2022-10-02 23:52:32 Network filter and lock are using nftables
2022-10-02 23:52:32 Successfully loaded kernel module nf_tables
2022-10-02 23:52:32 Network filter successfully initialized
2022-10-02 23:52:32 Session network filter and lock successfully enabled
2022-10-02 23:52:32 AirVPN bootstrap servers are now allowed to pass through the network filter
2022-10-02 23:52:32 Logging in AirVPN user sableslayer
2022-10-02 23:52:33 AirVPN user sableslayer successfully logged in
2022-10-02 23:52:33 Selected user key: New device
2022-10-02 23:52:33 Starting connection to AirVPN server Alhena, Toronto, Ontario (Canada)
2022-10-02 23:52:33 Starting VPN Connection
2022-10-02 23:52:33 TUN persistence is enabled.
2022-10-02 23:52:33 Logging out AirVPN user sableslayer
2022-10-02 23:52:33 Bluetit session terminated
@sableslayer
Can you please send us the Bluetit log taken just after the problem has occurred? For example, form a terminal:
sudo journalctl | grep bluetit > bluetit.log
and then send us the bluetit.log file.
