petra2022 1 Posted ... (edited) I have a python script running on a android phone which needs to be behind a VPN connection. I can connect via ssh to the phone but over the public VPN address which is very slow. I would like to connect directly over the local network. The problem is that the current Eddie app don't support wlan connections (System->Exclude local networks from the VPN, exclude local networks except mobile networks... which I suspect to be all wlan networks). Is there a way to allow local IP/Port addresses somewhere else? Perhaps with Custom Directives? Edit1: Eddi version 2.5 (VC27) Edit2: mobile networks are not WLAN connections (misunderstanding on my part), theoretically WLAN should work on a mobile phone if connecting to local ip address. It is not working in my case with AirVPN on, only if AirVPN is turned off on the mobile. Edited ... by petra2022 Share this post Link to post
Tech Jedi Alex 1524 Posted ... 40 minutes ago, petra2022 said: The problem is that the current Eddie app don't support wlan connections Huh? It does. It's the mobile networks that are not treated as local networks, because they aren't. 45 minutes ago, petra2022 said: I would like to connect directly over the local network This should be possible by default. You are using a local IP address to connect, right? Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
petra2022 1 Posted ... (edited) 38 minutes ago, OpenSourcerer said: Huh? It does. It's the mobile networks that are not treated as local networks, because they aren't. This should be possible by default. You are using a local IP address to connect, right? Yes, the local IP address starts with 192.168 which I viewed with ifconfig on the mobile device. The ssh connection works fine when i disconnect mobile VPN. As soon the VPN connection is active the ssh 192.168... command on my PC is blocked and after some time I get a timeout error. I tryied also to disable the VPN-Lock option on the phone, but still no connection with VPN active. Edited ... by petra2022 Share this post Link to post
Tech Jedi Alex 1524 Posted ... Can you post the logs after a connection, please? Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
petra2022 1 Posted ... Eddie Log created on 25 Sep 2022 18:42:21 UTC Eddie for Android 2.5 Version Code 27 --- App and device information --- Eddie Version Code: 27 Eddie Version Name: 2.5 Eddie Library 1.4 - 30 September 2021 Eddie Library API level: 7 Architecture: arm64-v8a (Arm 64 bit) Platform: Android Manufacturer: DOOGEE Model: S59Pro Device: S59Pro Board: k62v1_64_bsp Brand: DOOGEE Product: S59Pro_EEA Hardware: mt6762 Supported ABIs: arm64-v8a armeabi-v7a armeabi Host: release ID: QP1A.190711.020 Display: DOOGEE-S59Pro-Android10-20201202 Android API Level: 29 Android Codename: REL Android Version Release: 10 Android Version Incremental: 1598247913 Fingerprint: DOOGEE/S59Pro_EEA/S59Pro:10/QP1A.190711.020/1598247913:user/release-keys Type: user Tags: release-keys User: release Language: en Rooted device: false Network: WIFI Screen Width: 720 Screen Height: 1430 Screen Density: 2 Screen Density DPI: 320 Screen XDPI: 295 Screen YDPI: 295 Total RAM: 3823 Mb Free RAM: 2201 Mb Threshold Memory: 324 Mb Low Memory: false App Total Memory: 7 Mb App Max Memory: 256 Mb App Free Memory: 3 Mb Bootloader: unknown --- Settings dump --- airvpn_default_protocol: UDP airvpn_default_port: 443 airvpn_default_ip_version: IPv4 airvpn_default_tls_mode: tls-crypt airvpn_quick_connect_mode: auto airvpn_cipher: SERVER airvpn_forbid_quick_connection_to_user_country: true airvpn_custom_bootstrap_servers: airvpn_server_whitelist: airvpn_server_blacklist: airvpn_country_whitelist: airvpn_country_blacklist: airvpn_country_blacklist: airvpn_current_local_country: Auto enable_master_password: false system_vpn_lock: false system_vpn_boot_priority: AirVPN-Best-Server,AirVPN-Default-Server,AirVPN-Default-Country,Default-OpenVPN-Profile,Last-Connected-Profile system_vpn_reconnect: true system_vpn_reconnect_retries: -1 system_dns_override_enable: false system_dns_custom: system_proxy_enable: false system_persistent_notification: true system_notification_sound: true system_show_message_dialogs: true system_forced_mtu: system_application_filter_type: 0 system_application_filter: system_application_language: system_first_run: true system_start_vpn_at_boot: true system_last_profile_is_connected: true is_always_on_vpn: off vpn_lockdown: off system_exclude_local_networks: true system_pause_vpn_when_screen_is_off: false system_airvpn_remember_me: true ovpn3_tls_version_min: tls_1_2 ovpn3_protocol: ovpn3_ipv6: ovpn3_timeout: 60 ovpn3_tun_persist: true ovpn3_compression_mode: yes ovpn3_synchronous_dns_lookup: false ovpn3_autologin_sessions: true ovpn3_disable_client_cert: false ovpn3_ssl_debug_level: 0 ovpn3_default_key_direction: -1 ovpn3_tls_cert_profile: ovpn3_proxy_host: ovpn3_proxy_port: ovpn3_proxy_allow_cleartext_auth: false ovpn3_custom_directives: --- Log dump --- 25 Sep 2022 18:42:09 UTC [Info] Trying to connect AirVPN server Peony at Sao Paulo, Brazil - Protocol UDP, Port 443 25 Sep 2022 18:42:09 UTC [Info] VPN Lock is disabled 25 Sep 2022 18:42:09 UTC [Info] Local networks are exempted from the VPN 25 Sep 2022 18:42:09 UTC [Info] Connected to WIFI 25 Sep 2022 18:42:09 UTC [Debug] VPNService.networkStatusChanged() action: 'SYSTEM_RESUME' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Disposing current OpenVPN client 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Releasing VPN Client 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Successfully created a new OpenVPN client 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'tls_version_min' set to 'tls_1_2' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'protocol' set to '' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'ipv6' set to '' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'timeout' set to '60' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'tun_persist' set to 'true' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'compression_mode' set to 'yes' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'synchronous_dns_lookup' set to 'false' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'autologin_sessions' set to 'true' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'disable_client_cert' set to 'false' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'ssl_debug_level' set to '0' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'default_key_direction' set to '-1' 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN client: option 'tls_cert_profile' set to '' 25 Sep 2022 18:42:09 UTC [Info] Starting VPN thread 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Starting OpenVPN Client 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Loading profile to VPN Client 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.protoOverride: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.connTimeout: 60 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.compressionMode: yes 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.allowUnusedAddrFamilies: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.tlsVersionMinOverride: tls_1_2 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.tlsCertProfileOverride: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.disableClientCert: 0 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.proxyHost: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.proxyPort: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.proxyAllowCleartextAuth: 0 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.defaultKeyDirection: -1 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.sslDebugLevel: 0 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.autologinSessions: 1 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.tunPersist: 1 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: config.synchronousDnsLookup: 0 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Profile successfully loaded. Connecting to server. 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: OpenVPN core 3.7.1 AirVPN android arm64 64-bit 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: connect_attach() 25 Sep 2022 18:42:09 UTC [Debug] OpenVPNTunnel.onConnectAttach() 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Frame=512/2048/512 mssfix-ctrl=1250 25 Sep 2022 18:42:09 UTC [Debug] OpenVPN Event: type: 4, name: RESOLVE, info: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: connect_pre_run() 25 Sep 2022 18:42:09 UTC [Debug] OpenVPNTunnel.onConnectPreRun() 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: connect_run() 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Contacting 45.162.228.173:443 via UDP 25 Sep 2022 18:42:09 UTC [Debug] OpenVPN Event: type: 5, name: WAIT, info: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: socket_protect(socket = 78) 25 Sep 2022 18:42:09 UTC [Debug] OpenVPNTunnel.onSocketProtect(socket: 78) 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Connecting to [45.162.228.173]:443 (45.162.228.173) via UDPv4 25 Sep 2022 18:42:09 UTC [Debug] OpenVPN Event: type: 7, name: CONNECTING, info: 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Tunnel Options:V4,dev-type tun,link-mtu 1522,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-GCM,auth [null-digest],keysize 256,key-method 2,tls-client 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: Peer Info: IV_VER=3.7.1 AirVPN IV_PLAT=android IV_NCP=2 IV_TCPNL=1 IV_PROTO=30 IV_CIPHERS=AES-256-GCM IV_LZO=1 IV_LZO_SWAP=1 IV_LZ4=1 IV_LZ4v2=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 IV_AUTO_SESS=1 IV_GUI_VER=Eddie Library 1.4 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org CA/emailAddress=info@airvpn.org, signature: RSA-SHA512 25 Sep 2022 18:42:09 UTC [Info] Eddie Library: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=Peony/emailAddress=info@airvpn.org, signature: RSA-SHA512 25 Sep 2022 18:42:10 UTC [Info] Eddie Library: SSL Handshake: peer certificate: CN=Peony, 4096 bit RSA, cipher: TLS_CHACHA20_POLY1305_SHA256 TLSv1.3 Kx=any Au=any Enc=CHACHA20/POLY1305(256) Mac=AEAD 25 Sep 2022 18:42:10 UTC [Info] Eddie Library: Session is ACTIVE 25 Sep 2022 18:42:10 UTC [Debug] OpenVPN Event: type: 8, name: GET_CONFIG, info: 25 Sep 2022 18:42:10 UTC [Info] Eddie Library: Sending PUSH_REQUEST to server... 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: OPTIONS: 0 [route] [192.168.1.0] [255.255.255.0] [net_gateway] 1 [comp-lzo] [no] 2 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 3 [dhcp-option] [DNS] [10.22.170.1] 4 [dhcp-option] [DNS6] [fde6:7a:7d20:12aa::1] 5 [tun-ipv6] 6 [route-gateway] [10.22.170.1] 7 [topology] [subnet] 8 [ping] [10] 9 [ping-restart] [60] 10 [ifconfig-ipv6] [fde6:7a:7d20:12aa::1099/64] [fde6:7a:7d20:12aa::1] 11 [ifconfig] [10.22.170.155] [255.255.255.0] 12 [peer-id] [0] 13 [cipher] [AES-256-GCM] 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: PROTOCOL OPTIONS: cipher: AES-256-GCM digest: NONE ncp enabled: yes key-derivation: OpenVPN PRF compress: LZO_STUB peer ID: 0 control channel: tls-crypt enabled 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_new() 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderNew() 25 Sep 2022 18:42:11 UTC [Debug] OpenVPN Event: type: 9, name: ASSIGN_IP, info: 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_address(address = 10.22.170.155, prefix_length = 24, gateway = 10.22.170.1, ipv6 = 0, net30 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddAddress(address: 10.22.170.155, prefix_length: 24, gateway: 10.22.170.1, ipv6: false, net30: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_address(address = fde6:7a:7d20:12aa::1099, prefix_length = 64, gateway = fde6:7a:7d20:12aa::1, ipv6 = 1, net30 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddAddress(address: fde6:7a:7d20:12aa::1099, prefix_length: 64, gateway: fde6:7a:7d20:12aa::1, ipv6: true, net30: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 0.0.0.0, prefix_length = 1, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 0.0.0.0, prefix_length: 1, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 128.0.0.0, prefix_length = 2, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 128.0.0.0, prefix_length: 2, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.0.0.0, prefix_length = 9, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.0.0.0, prefix_length: 9, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.128.0.0, prefix_length = 11, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.128.0.0, prefix_length: 11, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.160.0.0, prefix_length = 13, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.160.0.0, prefix_length: 13, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.0.0, prefix_length = 24, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.0.0, prefix_length: 24, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.2.0, prefix_length = 23, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.2.0, prefix_length: 23, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.4.0, prefix_length = 22, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.4.0, prefix_length: 22, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.8.0, prefix_length = 21, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.8.0, prefix_length: 21, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.16.0, prefix_length = 20, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.16.0, prefix_length: 20, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.32.0, prefix_length = 19, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.32.0, prefix_length: 19, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.64.0, prefix_length = 18, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.64.0, prefix_length: 18, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.168.128.0, prefix_length = 17, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.168.128.0, prefix_length: 17, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.169.0.0, prefix_length = 16, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.169.0.0, prefix_length: 16, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.170.0.0, prefix_length = 15, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.170.0.0, prefix_length: 15, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.172.0.0, prefix_length = 14, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.172.0.0, prefix_length: 14, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.176.0.0, prefix_length = 12, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.176.0.0, prefix_length: 12, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 192.192.0.0, prefix_length = 10, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 192.192.0.0, prefix_length: 10, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 193.0.0.0, prefix_length = 8, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 193.0.0.0, prefix_length: 8, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 194.0.0.0, prefix_length = 7, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 194.0.0.0, prefix_length: 7, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 196.0.0.0, prefix_length = 6, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 196.0.0.0, prefix_length: 6, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 200.0.0.0, prefix_length = 5, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 200.0.0.0, prefix_length: 5, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 208.0.0.0, prefix_length = 4, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 208.0.0.0, prefix_length: 4, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = 224.0.0.0, prefix_length = 3, metric = -1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 224.0.0.0, prefix_length: 3, metric: -1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_route(address = ::, prefix_length = 0, metric = -1, ipv6 = 1) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: ::, prefix_length: 0, metric: -1, ipv6: true) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_dns_server(address = 10.22.170.1, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddDNSServer(address: 10.22.170.1, ipv6: false) 25 Sep 2022 18:42:11 UTC [Debug] VPNContext.doAddDNS(): Adding DNS server '10.22.170.1' 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_add_dns_server(address = fde6:7a:7d20:12aa::1, ipv6 = 1) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderAddDNSServer(address: fde6:7a:7d20:12aa::1, ipv6: true) 25 Sep 2022 18:42:11 UTC [Debug] VPNContext.doAddDNS(): Adding DNS server 'fde6:7a:7d20:12aa::1' 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_set_allow_family(af = 2, allow = 1) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderSetAllowFamily(af: AF_INET4, allow: true) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_set_allow_family(af = 10, allow = 1) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderSetAllowFamily(af: AF_INET6, allow: true) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_set_remote_address(address = 45.162.228.173, ipv6 = 0) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderSetRemoteAddress(address: 45.162.228.173, ipv6: false) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_set_layer(layer = 3) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderSetLayer(layer: 3) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_set_session_name(name = 45.162.228.173) 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderSetSessionName(name: 45.162.228.173) 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: tun_builder_establish() 25 Sep 2022 18:42:11 UTC [Debug] OpenVPNTunnel.onTunBuilderEstablish() 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: TunPersist: saving tun context: Session Name: 45.162.228.173 Layer: OSI_LAYER_3 Remote Address: 45.162.228.173 Tunnel Addresses: 10.22.170.155/24 -> 10.22.170.1 fde6:7a:7d20:12aa::1099/64 -> fde6:7a:7d20:12aa::1 [IPv6] Reroute Gateway: IPv4=1 IPv6=1 flags=[ ENABLE REROUTE_GW DEF1 BYPASS_DHCP IPv4 IPv6 ] Block IPv4: no Block IPv6: no Add Routes: Exclude Routes: 192.168.1.0/24 DNS Servers: 10.22.170.1 fde6:7a:7d20:12aa::1 [IPv6] Search Domains: 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: Connected via tun 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: LZO init swap=0 asym=1 25 Sep 2022 18:42:11 UTC [Info] Eddie Library: Comp-stub init swap=0 25 Sep 2022 18:42:11 UTC [Info] CONNECTED to VPN (AirVPN server Peony - Sao Paulo, Brazil) 45.162.228.173 Defined: 1 User: Server Host: 45.162.228.173 Server Port: 443 Server Protocol: UDPv4 Server IP: 45.162.228.173 VPN IPv4: 10.22.170.155 VPN IPv6: fde6:7a:7d20:12aa::1099 Gateway IPv4: 10.22.170.1 Gateway IPv6: fde6:7a:7d20:12aa::1 Tunnel Name: tun eddi2.log Share this post Link to post
petra2022 1 Posted ... It seems there is an issue with the mobile App. Where can I post a ticket then? Share this post Link to post
petra2022 1 Posted ... I wrote to the Support Team, after analyzing my situation they suggested me to use Eddi 3.0 for Android instead of Eddi 2.5. Without any changes to termux I was able to connect over the LAN network to the phone. For others with the same kind of problem I am copy & pasting the conversation to here: ------------------------------------------------------------------------------------------------------ Quote Hello and thank you for your choice! OpenVPN does not restrict communications within the local network, but the ssh daemon might bind to the virtual tun interface and therefore it is no more reachable on the physical interface. The fact that it can be reached over the VPN server exit-IP address (with port forwarding, we assume) is telling. Furthermore, if "Always on VPN" Android setting is enabled, no traffic should be allowed outside the VPN tunnel while the tunnel is up. On the other hand, if you disable that option and also "Block traffic if VPN is not active", then you might have traffic leaks in case of unexpected disconnections. Do you have a termux configuration file where you can check bind options? Kind regards AirVPN Support Team ------------------------------------------------------------------------------------------------------------------ Hello Support Team,Thanks for the suggestion. But it still not working. I have looked into the sshd_config file, there where no binding options specified. When I start the sshd with debug option it prints out the bindingsphone$ sshd -d ... debug1: Bind to port 8022 on ::. Server listening on :: port 8022. debug1: Bind to port 8022 on 0.0.0.0. Server listening on 0.0.0.0 port 8022. looks very general to me. Connection with AirVPN off, it connects just finePC$ ssh myuser@192.168.1.8 -p 8022but the same command is not working with AirVPN on. In the sshd_config file I also tried insert ListenAddress 192.168.1.8. What is strange for me thou, when AirVPN is on and sshd is not running I getssh: connect to host 192.168.1.8 port 8022: Connection refusederror and with sshd is runningssh: connect to host 192.168.1.8 port 8022: Connection timed outSomehow AirVPN allows to access the IP and port but sshd is not able to establish a complete connection and hangs silent until a time out. Does sshd use a additional communication channel, which AirVPN is still blocking? I feel I am so close to the solution. Any further suggestions? --------------------------------------------------------------------------------- Quote Hello! 0.0.0.0 means that the daemon is listening to all the interfaces, so no problems here. When sshd is not running, connection refused is expected: the kernel just doesn't know where to send the packet to (the port doesn't exist). Connection timeout, on the other hand, makes us think that the packet is not refused by the kernel, but dropped. This is a problem which might be caused by OpenVPN, but not on all devices strangely... let's make a cross-check. If possible, install Eddie 3.0 beta 2 from here:https://airvpn.org/forums/topic/51587-eddie-android-edition-30-preview-available/ This version includes a special feature, dedicated to WireGuard, to allow access to and from the local network (normally WireGuard would not allow them), by explicitly leaving entire private subnets (all the possible ones in IPv4 and IPv6 spaces) outside the tunneling scope. If possible, install Eddie from the APK. run it, open the "Settings" view and expand "System", then enable "Exclude local networks from the VPN". Connect USING WIREGUARD (default configuration), and not OpenVPN, from the quick connection tab or the AirVPN servers tab, then test again whether you can reach sshd locally. Kind regards AirVPN Support Team 1 Tech Jedi Alex reacted to this Share this post Link to post
