yorwos 1 Posted ... I have been using a lot the NL servers. Last weeks I noticed that when I tried to open my gmail account I landed on the russian version of gmail. I disconnected/reconnected back to NL. Stay connected a few days, back to russian gmail then. This doesn't look normal ... But is it ? 1 Updater reacted to this Share this post Link to post
Tech Jedi Alex 1524 Posted ... I remember something like this with Google but that was years ago. Might be another geolocation error. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Updater 1 Posted ... Same experience. I hope it's my paranoia, but i think these servers are compromised. New installation Linux, new installation windows 10 real endpoint is clearly Russia not the Netherlands as expected. Traffic seems to be routed. Share this post Link to post
Staff 10432 Posted ... 3 hours ago, Updater said: Same experience. I hope it's my paranoia, but i think these servers are compromised. New installation Linux, new installation windows 10 real endpoint is clearly Russia not the Netherlands as expected. Traffic seems to be routed. For your comfort and peace of mind, check with traceroute (tracert in Windows) or mtr, and/or access various end points which tell you the IP address your packets come from. Typical speed tests sites and "what is my address" web services are perfect. Compare the IP address you get with the supposed exit-IP address of the VPN server you're connected to and verify they match. Finally, query the IANA database (with whois) for a final cross-check. Repeat multiple times for each server to minimize the likelihood that you end up to services which are accomplices of the attackers and therefore mask your IP address making you believe that you have a perfectly fine IP address while in reality your packet has come out from inside the evil Russian network. As a welcome and smart side-effect, while the attackers could do nothing with the data in transit inside their nodes because of end-to-end encryption, a re-routing of such a kind which would add an additional exit node would turn infringement notices against us exactly to zero, and alas this is not what we observe, not at all 🙄. We have never met such kind and gentle attackers, unfortunately. Kind regards 😋 3 The_Skull, Updater and Riddick reacted to this Share this post Link to post
Riddick 13 Posted ... On 9/14/2022 at 6:13 PM, Updater said: Same experience. I hope it's my paranoia, but i think these servers are compromised. New installation Linux, new installation windows 10 real endpoint is clearly Russia not the Netherlands as expected. Traffic seems to be routed. Same here usually connected via NL server Miram showing russian for a week or so when searching on google.com/nl did not notice the language change on Gmail though! Quote C:\>tracert google.com Tracing route to google.com [142.250.186.110] over a maximum of 30 hops: 1 10 ms 10 ms 10 ms 10.24.86.1 2 17 ms 16 ms 12 ms hosted-by-macrobash.com [134.19.179.249] 3 10 ms 11 ms 10 ms 37.123.210.78 4 18 ms 23 ms 17 ms 37.123.210.21 5 53 ms 53 ms 53 ms 109.239.136.80 6 52 ms 53 ms 52 ms 108.170.250.130 7 54 ms 53 ms 53 ms 142.251.79.148 8 54 ms 53 ms 53 ms 142.251.51.185 9 57 ms 57 ms 55 ms 209.85.248.95 10 55 ms 73 ms 54 ms 209.85.252.76 11 55 ms 56 ms 55 ms 108.170.252.1 12 55 ms 55 ms 55 ms 142.250.214.193 13 54 ms 55 ms 55 ms fra24s06-in-f14.1e100.net [142.250.186.110] Trace complete. C:\>tracert google.nl Tracing route to google.nl [172.217.16.131] over a maximum of 30 hops: 1 9 ms 10 ms 10 ms 10.24.86.1 2 15 ms 15 ms 17 ms hosted-by-macrobash.com [134.19.179.249] 3 20 ms 11 ms 11 ms 37.123.210.78 4 25 ms 26 ms 12 ms 37.123.210.21 5 46 ms 46 ms 46 ms 178.18.227.12.ix.dataix.eu [178.18.227.12] 6 51 ms 48 ms 46 ms 74.125.244.181 7 48 ms 49 ms 48 ms 142.251.61.221 8 48 ms 49 ms 48 ms 142.251.238.73 9 51 ms 52 ms 51 ms 209.85.245.88 10 50 ms 51 ms 50 ms 108.170.236.248 11 50 ms 50 ms 50 ms 108.170.251.129 12 51 ms 51 ms 51 ms 66.249.94.245 13 51 ms 51 ms 50 ms zrh04s06-in-f131.1e100.net [172.217.16.131] Trace complete. Hide Riddick's signature Hide all signatures You're not afraid of the dark web, are you ? Share this post Link to post
Dawind 4 Posted ... This is normal for Google. Since geoIP is such a mess, they don't completely trust what geoIP databases report. Instead they use the data they get from browsers visiting from each IP and try to guess if some IP is now being used elsewhere. Since Russia is currently heavily censoring internet access, AirVPN likely has a lot of Russian users who happen to be using NL servers. Google detects a lot of users with Russian locale are using NL node IPs -> they start offering Russian site by default. Not sure if there are workarounds for this, other than logging in. But this is not a sign of compromise, so no need to be paranoid. If Russia really was listening, they wouldn't route traffic through Russia. ;) 2 1 Valerian, Stalinium and The_Skull reacted to this Share this post Link to post
Kenwell 9 Posted ... It's very very annoying ! Connected Caph Netherlands Netherlands Россия Москва - На основе ваших предыдущих действий - Обновить I'm Dutch. Share this post Link to post
RYFA 1 Posted ... Same issue here for google and youtube on most of the netherlands servers all saying russia. Is this an issue for security and can Airvpn do anything to fix it? Because even if it's not an issue for security it's still extremely annoying and has been going on for a long time and is happening to more and more of the servers. Also what caused an issue like this to begin with? Hope to see this fixed soon. Thanks for the help. Share this post Link to post
Staff 10432 Posted ... Hello! You have already explanations in this very thread and it should be now clear that the problem is Google side. Contact Google! The more contacts they have showing them their error, the more likely they will fix it, although it's unlikely that Google fixes errors in its algorithms after human feedback On our side, we diligently have our addresses providers keep the IANA / ARIN etc. database records correct, as you can easily verify with whois. We don't have the power to fix Google errors. Locking the thread before we arrive to a stupidity overflow. Kind regards 1 The_Skull reacted to this Share this post Link to post
