tad1
Eddie 2.21.8 Mint 23.0 disconnects every 3 secs
NOTE: Solved this before finishing the post. Will leave here in case it helps someone else.
Just upgraded Mint to version 23 and eddie-ui 2,20 stopped working.
. 2022.08.09 20:19:00 - IPv6 restored on network adapter (default)
. 2022.08.09 20:19:00 - IPv6 restored on network adapter (eno1)
. 2022.08.09 20:19:00 - IPv6 restored on network adapter (wlp2s0)
. 2022.08.09 20:19:00 - Connection terminated.
I 2022.08.09 20:19:02 - Cancel requested.
So I upgraded to the latest version 2.21.8, same problem
Under Networking I have
   Layer IPv4: inside tunnel (must be supported)
   Layer IPv6: block
   Protocol used for connection: IPv4 only
   Switch to block..: unchecked
Everything else automatic
Noticed in the logs it said
OpenVPN > Cannot load inline certificate file
Which led me to this post
Problem solved. I create a new device on the AIRVPN website, logged out of eddie and picked the new device on logging in.
