Not connected, Your IP: 3.148.252.90
cheapsheep
ANSWERED AirVPN - API values (speed_read / speed_write)
Hi all,
is there any documentation about the API?
Specifically, i need to know what base unit is being used for the read and write speed, because the interface and api values do not match.
@Staff I thought the API returns Bytes?
5 hours ago, Staff said:
Brief documentation is here:
https://airvpn.org/faq/api/
Yes, in the returned sessions array speed_read and speed_write are in bytes per second.
How come the values do not match. As far as i understand the API should return what is also shown on the "Your VPN Sessions" page as "Current speed:" - at least approximately.
If so, the API should have returned ~56.000k bytes as download instead of 870k bytes.
Am i misunderstanding something?
@cheapsheep
Bugs were found and fixed. Can you please try again and check whether the problem is resolved?
Also, to clarify:
speed_read (read bytes per second from client to server, upload for client)
speed_write (written bytes per second from server to client, download for client)
Last but not least, Eddie reports amounts in (multiples of) bit/s while the API in B/s.
