anon1701 0 Posted ... I have (finally) got he Wireguard setup to AirVPN working (thanks to those that answered) - it was essentially fat fingered syndrome on my part + a bit of a misunderstanding. All good. So second question - can I do multiple tunnels. If we look at the AirVPN config file:[Interface]Address = 10.xx.yy.zz/10, ipv6 addressPrivateKey = AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADNS = 10.128.0.1, fd7d:76ee:e68f:a993::1[Peer]PublicKey = BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBPresharedKey = CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCEndpoint = 146.70.94.2:1637AllowedIPs = 0.0.0.0/0, ::/0PersistentKeepalive = 15 The bit that has me slightly worried is the Address under Interface. Its the same in all the AirVPN Config files. Is this likley to cause an issue with having two tunnels on the same network? Quote Share this post Link to post
SurprisedItWorks 53 Posted ... Have you tried having each config set up with a different AirVPN "device"? That may give you the disjoint subnets you need. Quote Share this post Link to post
anon1701 0 Posted ... Thats a thought [Interface] Address = 10.aaa.bbb.ccc/10 - which is different. PrivateKey = DNS = 10.128.0.1 [Peer] PublicKey = PresharedKey = Endpoint = 213.152.161.180:1637 AllowedIPs = 0.0.0.0/0, ::/0 PersistentKeepalive = 15 Works - thank you Any idea why AirVPN use a /10 rather than something a lot smaller - its only a tunnel Quote Share this post Link to post
SurprisedItWorks 53 Posted ... No idea. Perhaps one of the more experienced network guys here can enlighten us. Quote Share this post Link to post
go558a83nk 382 Posted ... 1 hour ago, Aardvark56 said: Thats a thought [Interface] Address = 10.aaa.bbb.ccc/10 - which is different. PrivateKey = DNS = 10.128.0.1 [Peer] PublicKey = PresharedKey = Endpoint = 213.152.161.180:1637 AllowedIPs = 0.0.0.0/0, ::/0 PersistentKeepalive = 15 Works - thank you Any idea why AirVPN use a /10 rather than something a lot smaller - its only a tunnel I've used /32 for multiple pfsense clients and it works fine. Not sure why /10 is in the configs. Quote Share this post Link to post
anon1701 0 Posted ... I just tried changing to /24 rather than /10 The second gateway now comes up, whereas before it just stayed down due to a routing issue causing a monitor issue So I went further and changed one tunnel to /29 and the other to /26 (due to unfortunate choice of .223 by AirVPN which is a broadcast address for anything smaller Still works Quote Share this post Link to post
