votantonio
ANSWERED Torrent speed peaks and goes down constantly
Hello
This started some week ago, before everything was fine.
I'm trying to run torrent with airvpn, but the download speed goes up, peaks and goes down for few second, then peaks agin goes down in infinite loop.
I have tried without VPN to exclude the possibility of some hardware issue and I have no problems as shown in graph attached.
Canyouseeme, shows the torrent port open also when running on VPN.
I'm running Eddie 2.21.8 on Windows 10.
Any suggestion?
I've seen this before. I think your connection settings are incorrect. Can you post them?
I have removed Eddie and installed to the Open VPN client and the problem has disappeared.
As you said it may have been related to some incorrect setting in Eddie.
Please make sure everything is going through the VPN.  Without Eddie's windows filtering platform rules you have more potential for leaks.
