soolking 0 Posted ... Is it gonna work from Turkmenistan? most vpns are blocked here... Quote Share this post Link to post
Stalinium 55 Posted ... You can ask for a short trial period through Support in Client Area to try if it will work: https://airvpn.org/contact/ Keep in mind, AirVPN has many options to circumvent censorship: OpenVPN with many different ports (not just the default port!) WireGuard (easy to block but is a new protocol) 4 different server IPs for each server OpenVPN inside SSH tunnel OpenVPN inside stunnel worth to mention: IPv6 Quote Share this post Link to post
