Not connected, Your IP: 216.73.216.247
remy1234
Unable to Connect / Weird uninstall
After a restart to my PC (win7) and some time I noticed that the AirVPN client was no longer installed.  I was given the windows option to delete the shortcut and am not sure why.   I reinstalled the client and am have trouble connecting to the server.  Any help would be very appreciated.  Thank you.
I 2022.06.09 01:19:37 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2022.06.09 01:19:37 - Reading options from C:\Users\Aaron\AppData\Local\AirVPN\AirVPN.xml
. 2022.06.09 01:19:37 - Data Path: C:\Users\Aaron\AppData\Local\AirVPN
. 2022.06.09 01:19:37 - App Path: C:\Program Files\AirVPN
. 2022.06.09 01:19:37 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2022.06.09 01:19:37 - Command line arguments (1): path="home"
. 2022.06.09 01:19:37 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2022.06.09 01:19:37 - Updating systems & servers data ...
I 2022.06.09 01:19:37 - OpenVPN Driver - TAP-Windows Adapter V9 #3, version 9.24.2
I 2022.06.09 01:19:37 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2022.06.09 01:19:37 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2022.06.09 01:19:37 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2022.06.09 01:19:37 - Ready
. 2022.06.09 01:19:38 - Systems & servers data update completed
I 2022.06.09 01:19:41 - Session starting.
I 2022.06.09 01:20:15 - Checking authorization ...
! 2022.06.09 01:20:15 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:18 - Disconnecting
. 2022.06.09 01:20:18 - Connection terminated.
I 2022.06.09 01:20:21 - Checking authorization ...
! 2022.06.09 01:20:23 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:27 - Disconnecting
. 2022.06.09 01:20:27 - Connection terminated.
I 2022.06.09 01:20:30 - Checking authorization ...
! 2022.06.09 01:20:30 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:33 - Disconnecting
. 2022.06.09 01:20:33 - Connection terminated.
I 2022.06.09 01:20:36 - Checking authorization ...
! 2022.06.09 01:20:36 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:40 - Disconnecting
. 2022.06.09 01:20:40 - Connection terminated.
I 2022.06.09 01:20:43 - Checking authorization ...
! 2022.06.09 01:20:43 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:46 - Disconnecting
. 2022.06.09 01:20:46 - Connection terminated.
I 2022.06.09 01:20:49 - Checking authorization ...
! 2022.06.09 01:20:50 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:53 - Disconnecting
. 2022.06.09 01:20:53 - Connection terminated.
I 2022.06.09 01:20:56 - Checking authorization ...
! 2022.06.09 01:20:56 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:20:59 - Disconnecting
. 2022.06.09 01:20:59 - Connection terminated.
I 2022.06.09 01:21:02 - Checking authorization ...
! 2022.06.09 01:21:03 - Connecting to Haedus (United States, New York City)
! 2022.06.09 01:21:06 - Disconnecting
. 2022.06.09 01:21:06 - Connection terminated.
. 2022.06.09 01:21:09 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:09 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:09 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:09 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:09 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:09 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=fd2991e0 c96ead3c
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=aa8279ce 9a877026
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=35b0b9db 74de05c6
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=f52ff04d 1de34019
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=b534030b 61c0fda4
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=4d50a419 2fbfe4ad
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=d4722dd2 47149178
. 2022.06.09 01:21:09 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=35cc5aad 821f84d7
. 2022.06.09 01:21:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:09 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:09 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:09 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:09 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:09 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:09 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 5'
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 6'
. 2022.06.09 01:21:09 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:09 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:09 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:09 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:09 - OpenVPN > Exiting due to fatal error
I 2022.06.09 01:21:09 - Checking authorization ...
! 2022.06.09 01:21:09 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:10 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:10 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:10 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:10 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=3395db0d e24657e0
. 2022.06.09 01:21:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:10 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:10 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:10 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:10 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:10 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:10 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:13 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 5'
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:13 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:13 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:13 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:13 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:13 - Disconnecting
. 2022.06.09 01:21:13 - Connection terminated.
I 2022.06.09 01:21:16 - Checking authorization ...
! 2022.06.09 01:21:16 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:16 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:16 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:16 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:16 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:16 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:16 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=5c4f8f3d 8745ce9d
. 2022.06.09 01:21:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:16 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:16 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:16 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:16 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:16 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:17 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:19 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 6'
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:19 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:19 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:19 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:19 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:19 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:19 - Disconnecting
. 2022.06.09 01:21:19 - Connection terminated.
I 2022.06.09 01:21:22 - Checking authorization ...
! 2022.06.09 01:21:23 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:23 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:23 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:23 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:23 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:23 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=bdc1a9fc 903e5479
. 2022.06.09 01:21:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:23 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:23 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:23 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:23 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:23 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:23 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:25 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 5'
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:25 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:25 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:25 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:25 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:25 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:25 - Disconnecting
. 2022.06.09 01:21:25 - Connection terminated.
I 2022.06.09 01:21:28 - Checking authorization ...
! 2022.06.09 01:21:29 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:29 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:29 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:29 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:29 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:29 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:29 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=2c560637 58c14d51
. 2022.06.09 01:21:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:29 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:29 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:29 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:29 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:30 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:32 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 6'
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:32 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:32 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:32 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:32 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:32 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:32 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:32 - Disconnecting
. 2022.06.09 01:21:32 - Connection terminated.
I 2022.06.09 01:21:35 - Checking authorization ...
! 2022.06.09 01:21:35 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:35 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:35 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:36 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:36 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:36 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:36 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:36 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:36 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:36 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=9b31f4af 1805743c
. 2022.06.09 01:21:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:36 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:36 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:36 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:36 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:36 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:36 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:38 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 5'
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:38 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:38 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:38 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:38 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:38 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:38 - Disconnecting
. 2022.06.09 01:21:38 - Connection terminated.
I 2022.06.09 01:21:41 - Checking authorization ...
! 2022.06.09 01:21:42 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:42 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:42 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:42 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:42 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:42 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:42 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:42 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:42 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:42 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:42 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=fc426aa4 7a7ff5e7
. 2022.06.09 01:21:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:42 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:42 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:42 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:42 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:43 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:45 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 6'
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:45 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:45 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:45 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:45 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:45 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:45 - Disconnecting
. 2022.06.09 01:21:45 - Connection terminated.
I 2022.06.09 01:21:48 - Checking authorization ...
! 2022.06.09 01:21:49 - Connecting to Haedus (United States, New York City)
. 2022.06.09 01:21:49 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:21:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:21:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:21:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:21:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:49 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:21:49 - OpenVPN > UDPv4 link local: [undef]
. 2022.06.09 01:21:49 - OpenVPN > UDPv4 link remote: [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:49 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.115.138:443, sid=980d40d0 f3a72799
. 2022.06.09 01:21:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:21:49 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:21:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:21:49 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:21:49 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:21:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:21:49 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:21:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Haedus, emailAddress=info@airvpn.org
. 2022.06.09 01:21:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:21:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:21:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:21:49 - OpenVPN > [Haedus] Peer Connection Initiated with [AF_INET]146.70.115.138:443
. 2022.06.09 01:21:52 - OpenVPN > SENT CONTROL [Haedus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:21:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.224.1,route-gateway 10.26.224.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.224.70 255.255.255.0,peer-id 5'
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:21:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2022.06.09 01:21:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:21:52 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:21:52 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:21:52 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:21:52 - OpenVPN > Exiting due to fatal error
! 2022.06.09 01:21:52 - Disconnecting
. 2022.06.09 01:21:52 - Connection terminated.
I 2022.06.09 01:21:52 - Cancel requested.
! 2022.06.09 01:21:52 - Session terminated.
I 2022.06.09 01:26:54 - Session starting.
I 2022.06.09 01:26:54 - Checking authorization ...
! 2022.06.09 01:26:54 - Connecting to Pegasus (United States, Dallas, Texas)
! 2022.06.09 01:27:00 - Disconnecting
. 2022.06.09 01:27:00 - Connection terminated.
I 2022.06.09 01:27:03 - Checking authorization ...
! 2022.06.09 01:27:03 - Connecting to Pegasus (United States, Dallas, Texas)
! 2022.06.09 01:27:09 - Disconnecting
. 2022.06.09 01:27:09 - Connection terminated.
I 2022.06.09 01:27:12 - Checking authorization ...
! 2022.06.09 01:27:13 - Connecting to Pegasus (United States, Dallas, Texas)
! 2022.06.09 01:27:18 - Disconnecting
. 2022.06.09 01:27:18 - Connection terminated.
I 2022.06.09 01:27:21 - Checking authorization ...
! 2022.06.09 01:27:22 - Connecting to Pegasus (United States, Dallas, Texas)
! 2022.06.09 01:27:27 - Disconnecting
. 2022.06.09 01:27:27 - Connection terminated.
I 2022.06.09 01:27:27 - Cancel requested.
! 2022.06.09 01:27:27 - Session terminated.
. 2022.06.09 01:29:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:29:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:29:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:29:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:29:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:29:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:29:47 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:29:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 01:29:47 - OpenVPN > TCP connection established with [AF_INET]199.249.230.16:80
. 2022.06.09 01:29:47 - OpenVPN > TCPv4_CLIENT link local: [undef]
! 2022.06.09 01:30:50 - Activation of Network Lock - Windows Firewall
. 2022.06.09 01:30:55 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]199.249.230.16:80
. 2022.06.09 01:30:55 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.16:80, sid=4df55943 cc69e397
. 2022.06.09 01:30:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 01:30:55 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.16:80, sid=ac6df75f 51ace626
. 2022.06.09 01:30:55 - OpenVPN > Validating certificate key usage
. 2022.06.09 01:30:55 - OpenVPN > VERIFY KU OK
. 2022.06.09 01:30:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 01:30:55 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 01:30:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 01:30:55 - OpenVPN > VERIFY EKU OK
. 2022.06.09 01:30:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pegasus, emailAddress=info@airvpn.org
. 2022.06.09 01:30:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:30:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:30:55 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.16:80, sid=643b043b 31c5fdce
. 2022.06.09 01:30:55 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.16:80, sid=1b6c6a87 aa93ee86
. 2022.06.09 01:30:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 01:30:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:30:55 - OpenVPN > [Pegasus] Peer Connection Initiated with [AF_INET]199.249.230.16:80
. 2022.06.09 01:30:55 - OpenVPN > SENT CONTROL [Pegasus]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 01:30:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 01:30:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.26.65.1,route-gateway 10.26.65.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.65.104 255.255.255.0,peer-id 0'
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1563
. 2022.06.09 01:30:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 01:30:55 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 01:30:55 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 01:30:55 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 01:30:55 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 01:30:55 - OpenVPN > Exiting due to fatal error
I 2022.06.09 01:31:04 - Session starting.
I 2022.06.09 01:31:04 - Checking authorization ...
W 2022.06.09 01:31:04 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:31:04 - Connecting to Kruger (United States, Chicago, Illinois)
. 2022.06.09 01:31:04 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:31:04 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:31:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:31:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:31:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:04 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:31:04 - OpenVPN > Attempting to establish TCP connection with [AF_INET]68.235.35.123:80 [nonblock]
. 2022.06.09 01:31:14 - OpenVPN > TCP: connect to [AF_INET]68.235.35.123:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 01:31:14 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 01:31:14 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 01:31:14 - Disconnecting
. 2022.06.09 01:31:14 - Connection terminated.
I 2022.06.09 01:31:17 - Checking authorization ...
W 2022.06.09 01:31:17 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:31:17 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 01:31:17 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:31:17 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:31:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:31:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:31:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:17 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:31:17 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 01:31:27 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 01:31:27 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 01:31:27 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 01:31:27 - Disconnecting
. 2022.06.09 01:31:27 - Connection terminated.
I 2022.06.09 01:31:30 - Checking authorization ...
W 2022.06.09 01:31:30 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:31:30 - Connecting to Fang (United States, Chicago, Illinois)
. 2022.06.09 01:31:30 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:31:30 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:31:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:31:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:31:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:30 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:31:30 - OpenVPN > Attempting to establish TCP connection with [AF_INET]68.235.48.107:80 [nonblock]
. 2022.06.09 01:31:40 - OpenVPN > TCP: connect to [AF_INET]68.235.48.107:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 01:31:40 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 01:31:40 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 01:31:40 - Disconnecting
. 2022.06.09 01:31:40 - Connection terminated.
I 2022.06.09 01:31:44 - Checking authorization ...
W 2022.06.09 01:31:44 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:31:44 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 01:31:44 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:31:44 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:31:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:31:44 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:31:44 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:44 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:44 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:31:44 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 01:31:54 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 01:31:54 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 01:31:54 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 01:31:54 - Disconnecting
. 2022.06.09 01:31:54 - Connection terminated.
I 2022.06.09 01:31:57 - Checking authorization ...
W 2022.06.09 01:31:57 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:31:57 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 01:31:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:31:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:31:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:31:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:31:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:31:57 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:31:57 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
Here I am attempting to force connection to another server:
I 2022.06.09 01:59:07 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2022.06.09 01:59:07 - Reading options from C:\Users\Aaron\AppData\Local\AirVPN\AirVPN.xml
. 2022.06.09 01:59:08 - Data Path: C:\Users\Aaron\AppData\Local\AirVPN
. 2022.06.09 01:59:08 - App Path: C:\Program Files\AirVPN
. 2022.06.09 01:59:08 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2022.06.09 01:59:08 - Command line arguments (1): path="home"
. 2022.06.09 01:59:08 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2022.06.09 01:59:08 - Updating systems & servers data ...
I 2022.06.09 01:59:09 - OpenVPN Driver - TAP-Windows Adapter V9 #3, version 9.24.2
I 2022.06.09 01:59:09 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2022.06.09 01:59:09 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2022.06.09 01:59:09 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2022.06.09 01:59:09 - Ready
. 2022.06.09 01:59:13 - Systems & servers data update completed
! 2022.06.09 01:59:20 - Activation of Network Lock - Windows Firewall
I 2022.06.09 01:59:27 - Session starting.
I 2022.06.09 01:59:29 - Checking authorization ...
W 2022.06.09 01:59:29 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:59:29 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 01:59:30 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:59:30 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:59:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:59:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:59:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:59:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:59:30 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:59:30 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 01:59:40 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 01:59:40 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 01:59:40 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 01:59:40 - Disconnecting
. 2022.06.09 01:59:40 - Connection terminated.
I 2022.06.09 01:59:43 - Checking authorization ...
W 2022.06.09 01:59:43 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:59:43 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 01:59:43 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:59:43 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:59:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:59:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:59:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:59:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:59:43 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:59:43 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 01:59:53 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 01:59:53 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 01:59:53 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 01:59:53 - Disconnecting
. 2022.06.09 01:59:53 - Connection terminated.
I 2022.06.09 01:59:56 - Checking authorization ...
W 2022.06.09 01:59:56 - Authorization check failed, continue anyway ({1])
! 2022.06.09 01:59:56 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 01:59:56 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 01:59:56 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 01:59:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 01:59:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 01:59:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:59:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 01:59:56 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 01:59:56 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:00:06 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:00:06 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:00:06 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:00:06 - Disconnecting
. 2022.06.09 02:00:06 - Connection terminated.
I 2022.06.09 02:00:09 - Checking authorization ...
W 2022.06.09 02:00:09 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:00:09 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:00:09 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:00:09 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:00:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:00:09 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:00:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:09 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:00:09 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:00:19 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:00:19 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:00:19 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:00:20 - Disconnecting
. 2022.06.09 02:00:20 - Connection terminated.
I 2022.06.09 02:00:23 - Checking authorization ...
W 2022.06.09 02:00:23 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:00:23 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:00:23 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:00:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:00:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:00:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:00:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:23 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:00:23 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:00:33 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:00:33 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:00:33 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:00:33 - Disconnecting
. 2022.06.09 02:00:33 - Connection terminated.
I 2022.06.09 02:00:36 - Checking authorization ...
W 2022.06.09 02:00:36 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:00:36 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:00:36 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:00:36 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:00:36 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:00:36 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:00:36 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:36 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:36 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:00:36 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:00:46 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:00:46 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:00:46 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:00:46 - Disconnecting
. 2022.06.09 02:00:46 - Connection terminated.
I 2022.06.09 02:00:49 - Checking authorization ...
W 2022.06.09 02:00:49 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:00:49 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:00:49 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:00:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:00:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:00:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:00:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:00:49 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:00:49 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:00:59 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:00:59 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:00:59 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:00:59 - Disconnecting
. 2022.06.09 02:00:59 - Connection terminated.
I 2022.06.09 02:01:02 - Checking authorization ...
W 2022.06.09 02:01:02 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:01:02 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:01:02 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:01:02 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:01:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:01:02 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:01:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:02 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:01:02 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:01:12 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:01:12 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:01:12 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:01:13 - Disconnecting
. 2022.06.09 02:01:13 - Connection terminated.
I 2022.06.09 02:01:16 - Checking authorization ...
W 2022.06.09 02:01:16 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:01:16 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:01:16 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:01:16 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:01:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:01:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:01:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:16 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:01:16 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:01:26 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:01:26 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:01:26 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:01:26 - Disconnecting
. 2022.06.09 02:01:26 - Connection terminated.
I 2022.06.09 02:01:29 - Checking authorization ...
W 2022.06.09 02:01:29 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:01:29 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:01:29 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:01:29 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:01:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:01:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:01:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:29 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:01:29 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:01:39 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:01:39 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:01:39 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:01:39 - Disconnecting
. 2022.06.09 02:01:39 - Connection terminated.
I 2022.06.09 02:01:42 - Checking authorization ...
W 2022.06.09 02:01:42 - Authorization check failed, continue anyway ({1])
! 2022.06.09 02:01:42 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:01:42 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:01:42 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:01:42 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:01:42 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:01:42 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:42 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:01:42 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:01:42 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:01:52 - OpenVPN > TCP: connect to [AF_INET]199.249.230.16:80 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
. 2022.06.09 02:01:52 - OpenVPN > SIGUSR1[soft,init_instance] received, process restarting
. 2022.06.09 02:01:52 - OpenVPN > Restart pause, 5 second(s)
! 2022.06.09 02:01:52 - Disconnecting
. 2022.06.09 02:01:52 - Connection terminated.
I 2022.06.09 02:01:52 - Cancel requested.
! 2022.06.09 02:01:52 - Session terminated.
! 2022.06.09 02:02:03 - Deactivation of Network Lock
I 2022.06.09 02:02:12 - Session starting.
I 2022.06.09 02:02:12 - Checking authorization ...
! 2022.06.09 02:02:12 - Connecting to Aquila (United States, Fremont, California)
. 2022.06.09 02:02:12 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:02:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:02:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:02:13 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:02:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:13 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:02:13 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.223.129:80 [nonblock]
. 2022.06.09 02:02:14 - OpenVPN > TCP connection established with [AF_INET]199.249.223.129:80
. 2022.06.09 02:02:14 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2022.06.09 02:02:14 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]199.249.223.129:80
. 2022.06.09 02:02:14 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.223.129:80, sid=28c7dcd1 4bfb6bca
. 2022.06.09 02:02:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 02:02:14 - OpenVPN > Validating certificate key usage
. 2022.06.09 02:02:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 02:02:14 - OpenVPN > VERIFY KU OK
. 2022.06.09 02:02:14 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 02:02:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 02:02:14 - OpenVPN > VERIFY EKU OK
. 2022.06.09 02:02:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aquila, emailAddress=info@airvpn.org
. 2022.06.09 02:02:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 02:02:16 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 02:02:16 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 02:02:16 - OpenVPN > [Aquila] Peer Connection Initiated with [AF_INET]199.249.223.129:80
. 2022.06.09 02:02:18 - OpenVPN > SENT CONTROL [Aquila]: 'PUSH_REQUEST' (status=1)
. 2022.06.09 02:02:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.9.161.1,route-gateway 10.9.161.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.9.161.12 255.255.255.0,peer-id 0'
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: route options modified
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.09 02:02:18 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1563
. 2022.06.09 02:02:18 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2022.06.09 02:02:18 - OpenVPN > open_tun, tt->ipv6=0
. 2022.06.09 02:02:18 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5AD17D36-905E-453C-BC7F-351EB8CF4396}.tap
. 2022.06.09 02:02:18 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2022.06.09 02:02:18 - OpenVPN > Exiting due to fatal error
! 2022.06.09 02:02:18 - Disconnecting
. 2022.06.09 02:02:18 - Connection terminated.
I 2022.06.09 02:02:21 - Checking authorization ...
! 2022.06.09 02:02:22 - Connecting to Pegasus (United States, Dallas, Texas)
. 2022.06.09 02:02:22 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2022.06.09 02:02:22 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2022.06.09 02:02:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2022.06.09 02:02:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2022.06.09 02:02:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:22 - OpenVPN > Socket Buffers: R=[8192->131072] S=[64512->131072]
. 2022.06.09 02:02:22 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.16:80 [nonblock]
. 2022.06.09 02:02:23 - OpenVPN > TCP connection established with [AF_INET]199.249.230.16:80
. 2022.06.09 02:02:23 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2022.06.09 02:02:23 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]199.249.230.16:80
. 2022.06.09 02:02:23 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.16:80, sid=8831cdd0 05970d9f
. 2022.06.09 02:02:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.09 02:02:23 - OpenVPN > Validating certificate key usage
. 2022.06.09 02:02:23 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2022.06.09 02:02:23 - OpenVPN > VERIFY KU OK
. 2022.06.09 02:02:23 - OpenVPN > Validating certificate extended key usage
. 2022.06.09 02:02:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.09 02:02:23 - OpenVPN > VERIFY EKU OK
. 2022.06.09 02:02:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pegasus, emailAddress=info@airvpn.org
. 2022.06.09 02:02:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 02:02:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2022.06.09 02:02:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2022.06.09 02:02:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2022.06.09 02:02:25 - OpenVPN > [Pegasus] Peer Connection Initiated with [AF_INET]199.249.230.16:80
Before any investigation starts, please upgrade Eddie. You are running a version dated August 2015 which is no more compatible with our service (thank you very much, you are indeed a long time customer!). You can download Eddie latest release for Windows here:
https://airvpn.org/windows
Let us know whether the new version resolves all the problems.
I was able to get the client working using 2.21.6.  Other versions, fairly recent to that one, also had the same connection issue detailed above.  Hopefully it continues to function...
