SpitRR93
ANSWERED Eddie Connecting/Disconnecting/Reconnecting every 3 seconds
Hey,
so I just downloaded Eddie and tried to connect to a Server. It then connected, immediately disconnected and reconnected after 3 seconds -> repeat
I have no clue why its acting like that. Can someone please help me? Thanks in advance.
Not sure which infos you guys need. I downloaded the latest Eddie version(2.21.8) for Windows 10(64 bit)
Logs:
I 2022.05.29 13:05:48 - Session starting.
I 2022.05.29 13:05:49 - Checking authorization ...
. 2022.05.29 13:05:50 - Using WinTun network interface "LAN-Verbindung (ExpressVPN Wintun Driver)"
! 2022.05.29 13:05:50 - Connecting to Adhara (Germany, Frankfurt)
. 2022.05.29 13:05:50 - Routes, add 185.104.184.45/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)".
. 2022.05.29 13:05:50 - Routes, add 185.104.184.45/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists.
. 2022.05.29 13:05:50 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2022.05.29 13:05:50 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.05.29 13:05:50 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2022.05.29 13:05:50 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.05.29 13:05:50 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.05.29 13:05:50 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.05.29 13:05:50 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.05.29 13:05:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.104.184.45:443
. 2022.05.29 13:05:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.05.29 13:05:50 - OpenVPN > UDP link local: (not bound)
. 2022.05.29 13:05:50 - OpenVPN > UDP link remote: [AF_INET]185.104.184.45:443
. 2022.05.29 13:05:50 - OpenVPN > TLS: Initial packet from [AF_INET]185.104.184.45:443, sid=425df587 7d551ca1
. 2022.05.29 13:05:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.05.29 13:05:50 - OpenVPN > VERIFY KU OK
. 2022.05.29 13:05:50 - OpenVPN > Validating certificate extended key usage
. 2022.05.29 13:05:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.05.29 13:05:50 - OpenVPN > VERIFY EKU OK
. 2022.05.29 13:05:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Adhara, emailAddress=info@airvpn.org
. 2022.05.29 13:05:50 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2022.05.29 13:05:50 - OpenVPN > [Adhara] Peer Connection Initiated with [AF_INET]185.104.184.45:443
. 2022.05.29 13:05:51 - OpenVPN > SENT CONTROL [Adhara]: 'PUSH_REQUEST' (status=1)
. 2022.05.29 13:05:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.178.1,dhcp-option DNS6 fde6:7a:7d20:b2::1,tun-ipv6,route-gateway 10.4.178.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:b2::10e3/64 fde6:7a:7d20:b2::1,ifconfig 10.4.178.229 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2022.05.29 13:05:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.05.29 13:05:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.4.178.1'
. 2022.05.29 13:05:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:b2::1'
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.05.29 13:05:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.05.29 13:05:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.05.29 13:05:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.05.29 13:05:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.05.29 13:05:52 - OpenVPN > interactive service msg_channel=0
. 2022.05.29 13:05:52 - OpenVPN > open_tun
. 2022.05.29 13:05:52 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system.  You should be able to create an adapter by using tapctl.exe utility.
. 2022.05.29 13:05:52 - OpenVPN > Exiting due to fatal error
! 2022.05.29 13:05:52 - Disconnecting
. 2022.05.29 13:05:53 - Routes, delete 185.104.184.45/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)".
. 2022.05.29 13:05:53 - Routes, delete 185.104.184.45/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists.
. 2022.05.29 13:05:53 - Connection terminated.
I 2022.05.29 13:05:56 - Cancel requested.
! 2022.05.29 13:05:56 - Session terminated.
And once I installed the TAP-Windows adapter, it now says:
. 2022.05.29 13:22:01 - OpenVPN > All wintun adapters on this system are currently in use or disabled.
I tried to re-install the Driver and also to Deactivate -> Activate the driver. Both didn't work.
Greetings
Edited ... by SpitRR93
For some reason we will probably investigate, when ExpressVPN driver and software are installed OpenVPN and WireGuard on their own don't work properly anymore:
Quote
We don't know whether it's a highly customized driver which creates incompatibilities or it's just an interface lock problem caused by some Express process still running and interfering in the background. Anyway, we have noticed that by removing anything Express related, both OpenVPN and WireGuard work again just fine.
