prplshroud 1 Posted ... System: Ubuntu 22.04 VM Eddie: 2.21.6 Ubuntu system will not connect to a VPN host and just keeps retrying hosts. Here are the logs from the console for two attempt cycles with the client. I 2022.05.18 10:07:01 - Session starting. I 2022.05.18 10:07:01 - Checking authorization ... ! 2022.05.18 10:07:01 - Connecting to Edasich (Netherlands, Alblasserdam) . 2022.05.18 10:07:01 - Routes, add 213.152.161.213/32 for interface "ens33". . 2022.05.18 10:07:02 - Routes, add 213.152.161.213/32 for interface "ens33", already exists. . 2022.05.18 10:07:02 - OpenVPN > OpenVPN 2.5.5 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar 22 2022 . 2022.05.18 10:07:02 - OpenVPN > library versions: OpenSSL 3.0.2 15 Mar 2022, LZO 2.10 . 2022.05.18 10:07:02 - OpenVPN > OpenSSL: error:0A00018E:SSL routines::ca md too weak . 2022.05.18 10:07:02 - OpenVPN > Cannot load inline certificate file . 2022.05.18 10:07:02 - OpenVPN > Exiting due to fatal error ! 2022.05.18 10:07:02 - Disconnecting . 2022.05.18 10:07:02 - Sending soft termination signal . 2022.05.18 10:07:02 - Routes, delete 213.152.161.213/32 for interface "ens33". . 2022.05.18 10:07:02 - Routes, delete 213.152.161.213/32 for interface "ens33", not exists. . 2022.05.18 10:07:02 - Connection terminated. I 2022.05.18 10:07:05 - Checking authorization ... ! 2022.05.18 10:07:05 - Connecting to Kajam (Netherlands, Alblasserdam) . 2022.05.18 10:07:06 - Routes, add 213.152.161.87/32 for interface "ens33". . 2022.05.18 10:07:06 - Routes, add 213.152.161.87/32 for interface "ens33", already exists. . 2022.05.18 10:07:06 - OpenVPN > OpenVPN 2.5.5 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar 22 2022 . 2022.05.18 10:07:06 - OpenVPN > library versions: OpenSSL 3.0.2 15 Mar 2022, LZO 2.10 . 2022.05.18 10:07:06 - OpenVPN > OpenSSL: error:0A00018E:SSL routines::ca md too weak . 2022.05.18 10:07:06 - OpenVPN > Cannot load inline certificate file . 2022.05.18 10:07:06 - OpenVPN > Exiting due to fatal error ! 2022.05.18 10:07:06 - Disconnecting . 2022.05.18 10:07:06 - Sending soft termination signal . 2022.05.18 10:07:06 - Routes, delete 213.152.161.87/32 for interface "ens33". . 2022.05.18 10:07:06 - Routes, delete 213.152.161.87/32 for interface "ens33", not exists. . 2022.05.18 10:07:06 - Connection terminated. I have seen similar posts as this but with the windows client. Anyone have some thoughts on this? 1 jackjohnson reacted to this Quote Share this post Link to post
Staff 10449 Posted ... @prplshroud Hello! For a quick resolution, please renew your client certificate from your account "Devices" panel, available in your "Client Area" in airvpn.org web site, then log your account out and in again from Eddie's main window (or generate new configuration files if you don't use Eddie). We started signing client certificates through SHA512 since 2017, so you must have an older one: thank you, you're a long time customer! Explanation of the problem with additional details:https://airvpn.org/forums/topic/49811-urgent-cant-connect-to-vpn-anymore-on-openvpn-for-android-0725/?do=findComment&comment=169523 Kind regards 2 kanone123 and jackjohnson reacted to this Quote Share this post Link to post
prplshroud 1 Posted ... Yep! That did it. Runs like a champ now! Thank you! Was there any sort of announcement that I missed to do this? Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 15 hours ago, prplshroud said: Was there any sort of announcement that I missed to do this? It was the linked forum post alerting people to this problem, so no, no formal announcement. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
gooie 0 Posted ... I have just rebuilt my Ubuntu PC and also could not get Eddie to connect after reinstalling. Renewing website Certificate also worked for me - easy. Thanks ++ (member since 2017 ) Quote Share this post Link to post
montycristo55 0 Posted ... worked for me too - first time ubuntu user Quote Share this post Link to post
