Veep Peep
Checking route IPv4... Stuck
I upgraded to 2.21.6 today.
On Windows 10
Now it have on Checking route IPv4
(...4th try)
I checked a past thread, and it mentioned to uncheck Check AirVpn DNS.
did that, no luck.
Previous versioned worked fine for the longest time.
When I unistalled Eddie, my 'regular' internet seems to work fine.  Of course, this is not what I want...
What have I done???
Help and thank you!
Eddie_20220508_115429_115658.txt
Edited ... by Veep Peep
updated
Connect, then in Logs tab click the lifebelt icon on the right and paste/upload the output here.
Similar  issue here, some networks resets doesnt solve the issue
I'll post the log later today
best regards
Solved, i set an static dns entry in my ipv4 wlan interface, i hope that the vpn dns will still triggered.
BEST REGARDS
It is set for the tunnel adapter. Eddie overrides your static assignment and reverts it after disconnection, other VPN clients don't touch it at all. Connect, then go to IPLeak.net to verify.
Next time open your own thread, do not hijack the help threads of others, please.
Quote
this wasnt hijacking at all, it was the same error and may i helped the threadcreator that was my intention. similar people a similar problem, so more attention for help.
sorry no hard feelings
Quote
Good point 👍
best regards
Apologies for not responding sooner.
Things got busy and still are.
I will send the proper logs.
Do I need to install the TAP drivers or will the installer do that?
My current set up has the default gateway set up to point to my driver - or do I let Eddie config it?
@moejoe - you set set your DNS servers to google, not your internet provider default - and that fixed it for you?
After reconnect did it work
" Eddie overrides your static assignment and reverts it after disconnection "  @OpenSourcerer  (thanks!)
What I did find out - playing my video game thru the VPN did not impact my Ping!!!
It did everything before:
from network reinstall every device , uninstall vm software, everything from here: https://www.techrepublic.com/article/how-to-use-a-batch-file-to-reset-and-renew-a-network-connection-in-windows-10/   and some other things.
But nothing worked then i had set an static dns provider and now everything works flawless after an eddie  reconnect.
best regads
Let Eddie do all that.
This smells very, very fishy. Are you absolutely sure your connection is routed through the VPN? Check with IP APIs like ipleak.net!
Yes, I will have to check out why it seems slower.
Possible the AV servers are closer to the game servers ....but it still has to get to me...
Ok for another time.
Right now, i just want AirVPN to work again
Attached is the LifeSave icon save...
Thanks again,
V
EddieFail20220512.txt
@Veep Peep check as @OpenSourcerer mentioned if ure going through vpn if ure watching a vid.
Then u sould do some steps do reinitiate ur network.  like this mentioned here:
If this wont help u could reinstall ur network services:
https://www.techbout.com/update-reinstall-drivers-windows-64991/
Tried the .bat file.
Still not working.
Going to update the drivers...but before I do - anything jump out at you? 370512128_DeviceManagerNetworkAdapters.png.b61b388f7449f85fe5be099484f90c82.png
I uninstalled Eddie again, but when I reboot, I still get a quick Eddie Screen that pops up and disappears.
Thanks again for all the help and patience!
Eddie Fail 20220525.txt
U have some possibilities:
A.
1. Uninstal Eddie and any other vpn/virtual network apps
2 Reboot.
3 . Go in the Device Manager
4. Remove any Network Adapters which are listed here.
5. Go into  "Action" Menue, click " Scan for Hardware Changes"  wait for all reinstalling processes.
6. Rebot again.
7. Execute the batch file again.
8 Reboot again.
Note:  This is what i would do ( and have done that  already )  , cause i'm not able to diagnose/debug on a network layer level on every point.
B.
U could also try to set an static dns  server into the ip4 protocol settings  on ur network adapter which ure using for airvpn that i mentioned in an former thread.
I think this solved my Problem with the routing stuck issue after i did A first
C.
Another alternative is to reset the whole network, in windows 10. There is an option for it.
But then every Network Connections with Passwords are also removed.
May u consider C if u have every password ready  cause if sth. isnt working if u do A ure may better stick on an official MS option.
Everything is on ur own Risk but normally if u dont have an exotic wlan adapter everything should still work with option A
Hi @HeyWAZZab33
Not yet.
My computer is old, and I am concerned it won't find the right adapters...
But stay tuned, I am digging up some back up stuff
Did you upgrade then get the same issue?
Thanks,
Update.
I deleted the TAP adapter only.  I then reinstalled Eddie - and used the default settings.
Rebooted.
When I rebooted it prompted if I wanted Eddie install something.
Now I see Eddie Tunnel
instead of the TAP-9 Windows adapter
So I did not uninstall all network adapter...just the TAP-9.  I don't know why I did that.
whatismyip is showing the Eddie public exit id now.
Thoughts on this?
Thank you all, so much for helping!
V
Yes. But I'm not sure whether I was on 2.19.x before, because after downgrading to 2.21.6, I'm still running into some issues & 2.19.x does not work anymore.
I found a way to sidestep the problem though. For me it works as long as I connect to WiFi directly and not wait until Eddie starts up. Then I get no issues at all, even with 2.21.8. But it's not really a good solution, cause some of the traffic will leak my real world IP to the update servers etc.
On 6/4/2022 at 10:50 PM, Veep Peep said:
for now, I am going to skip the Version: 2.21.8  updates....
or should I????
Hello I have the very same issue. Stuck at "checking IPV4"
Did you actually solve it?
