Droopy
Utorrent
In Utorrent you can see there is a choice socks4, socks5, HTTPS, HTTP can I use this with Air VPN, as per the attached screenshot.
You don't need to tunnel uTorrent over a proxy when connected to AirVPN. It will result in a serious performance hit. The advantage is that in case of unexpected VPN disconnection chances that uTorrent will reveal your real IP address are lower, however if you secure your connection against leaks (see the permanent links in the announcements section of the forum) witch a firewall you will obtain higher security without performance being impaired.
I just purchased AirVPN and I am very lost.  After reading your answer, I am still lost.  What do I do with uTorrent to ensure that I can resume downloading safely?  I am very unfamiliar with terms such as "port forwarding."
very probably our answers to FAQ can help you.
Please read this https://airvpn.org/topic/9161-you-provide-remote-port-forwarding-what-is-it first, then read this https://airvpn.org/topic/9170-do-you-allow-p2p-how-can-i-optimize-performance-of-emule-and-bittorrent-with-airvpn
Feel free also to use the Forum "Search" function, which is powerful and can be very helpful, after years there's a good knowledge base on this forum, thanks to the invaluable contribution of the community. In case of any issue, anyway, do not hesitate to open a ticket.
