uwu73 1 Posted ... Hey guys Long term user of AirVPN here. I love it, never EVER had any issues with it. I currently use on a media server that sits in the corner of a room. No monitor, etc. I use TeamViewer to connect to the machine (Peppermint Linux) and connect Eddie. When I activate the network lock, over TeamViewer, the connection stays up and I can click the "Connect to recommended server" no problem. However, when I'm finished, and I disconnect Eddie, the TeamViewer connection drops and I cannot use it to deactivate the network lock (clearly because the network lock has stopped TeamViewer from connecting) My questions are: Why doesn't activating the network lock block TeamViewer before connecting (although I'm not overly fussed about knowing why) Is there a way of telling the network lock to allow connections from the LAN? At least if TeamViewer dropped off, I could then perhaps SSH in from another machine and deactivate the network block, for instance Anyway, its a pure annoyance, and not really AirVPN's fault - its doing its job. I'd just like to know if there is a solution, currently I have to hard reset the server when it happens (I could turn on the monitor but more often than not, it doesn't receive a signal from the graphics card - dodgy GVX card I think) I'm using Eddie 2.19.7 Thanks in advance, uwu73 Quote Share this post Link to post
Tech Jedi Alex 1521 Posted ... 8 hours ago, uwu73 said: Why doesn't activating the network lock block TeamViewer before connecting (although I'm not overly fussed about knowing why) Network Lock by default has an exception for the local network. It seems your NetLock only engages when it's actually connecting, not when you explicitly click on Enable Network Lock. Have a look at Eddie 2.20 or 2.21 beta. 8 hours ago, uwu73 said: Is there a way of telling the network lock to allow connections from the LAN? At least if TeamViewer dropped off, I could then perhaps SSH in from another machine and deactivate the network block, for instance TeamViewer is connecting you through the internet, it doesn't stay in your local network. You get disconnected because TeamViewer loses connection to the TeamViewer servers since NetLock blocks this kind of traffic going out. 8 hours ago, uwu73 said: Anyway, its a pure annoyance, and not really AirVPN's fault - its doing its job. Exactly. You need to use a protocol which stays in the local network, such as NX (NoMachine) or RFB (*VNC). Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
uwu73 1 Posted ... Thanks, using NoMachine should sort it out. I thought TeamViewer would be clever enough to connect locally. Cheers again Quote Share this post Link to post
Tech Jedi Alex 1521 Posted ... 4 hours ago, uwu73 said: I thought TeamViewer would be clever enough to connect locally. FYI, TeamViewer always was a cloud service. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
uwu73 1 Posted ... 10 hours ago, OpenSourcerer said: FYI, TeamViewer always was a cloud service. Yeah, don't normally use it - but for some reason I did on this server. NoMachine did the trick so I will remove TeamViewer. Be gone forever. Thanks again 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
