milky
AirVPN Eddie 2.20.0 Very slow connections
since the last few days connections are very slow, i.e., even sites load very slow and streams are laggy.
When disconnected from Eddie, the connections run fine - meaning as fast as usual.
Also sometimes the "Checking DNS" step takes ages.
Tried to change UDP Port as suggested here:
However, I don't understand Eddie's interface.
Within Settings->Protocols the only thing I can edit is the "Automatic"-checkbox. Nothing else in the windows is editable.
Log is attached.
Thanks!
log.log
Untick the box, then you can click in the table below.
Thanks.
I tested around a little bit with a few different servers/Germany and different ports 443/80/2018.
But honestly, the performance on each is lower than it used to be. Upload is okay as it seems. Download direction is not.
Also the performance has a large variance between different servers. Server from the Netherlands perform better.
Strange.
Wierd GUI in Eddit though.
