Not connected, Your IP: 160.79.108.15
Nasheayahu
New to AirVPN from ExpressVPN - Having connection problems
Since the new updates and features with ExpressVPN, I decided to purchase this subscription to see if I get the same problems which is blocking all apps from connecting to the internet on my Galaxy A32 SG, and in using the Hotspot for my HP ENVY x360 Laptop I also not able to connect to the internet.  So both VPN's are doing this with the default settings, I'm guessing this should not be happen right?  In addition after connecting with AirVPN on Ubuntu Studio 20.04.4 LTS my connection from MX Linux 21 using Remmina is disconnected and I can't log back in.
Can anyone walk me through on how to allow local apps and network through this VPN, this would also include being able to access local resources like my pfSense, using FileZilla to connect to my Off Line data Server etc?  So in other words I want to be able to access all local resources as well as the internet on my home network using AirVPN and this would have to work as well for my Laptop when I'm out on the road.
Thanks in advance!...
You left out pretty much all info on your setup.
So, one of the clients is a mobile. Which app are you trying to use for connecting to AirVPN?
So, a laptop is another client which connects to the phone for its internet connection. Are you trying to route the laptop's traffic through the VPN connection on the phone?
I'm guessing MX Linux is the OS running on that laptop? And you connect with it to an Ubuntu which is… a third client in your local home network or something? And you connect to AirVPN with this third client (Ubuntu)? But why the mobile internet connection, then, if you seem to have a LAN? No internet?
It's already the default usually. OpenVPN itself explicitly pushes a route for the local network the connecting client is in. Only exception would be Eddie on PC, though allowing the local network is already the default if it is engaged, too.
Please clarify your setup.
55 minutes ago, OpenSourcerer said:
Using Eddie
-- Yes, mobile; firefox, rumble, rsbn, basically all the ones I normally use during travel.
-- Yes, MX Linux 21, just about the same apps on my mobile I use here also, most of the time using it here because it more convenient.  When I'm out without my Laptop, then the apps are used.   I have Eddie installed  on my Laptop as well, with Eddie turned off on the mobile, it did connect to a VPN but keep failing on the IP4 scanning, so basically I could not connect through my mobile Hotspot.
-- Sorry about this one, I was referring to my Main IT Workstation (1) MX Linux, and Surveillance Camera setup (2) Ubuntu Mate with Eddie installed and connected.  When Eddie connects then (1) is disconnected and can't reconnect.
NOTE:  Both ExpressVPN and AirVPN (using Eddie) I'm not able to connect to other Workstations and Servers when connected.
Edited ... by Nasheayahu
additional info
Quote
Some logs would be cool to capture this failure for further analysis. In theory it shouldn't fail.
Quote
Another clarification needed: So MX Linux is connected to a CCTV setup run on Ubuntu at all times, and I'm guessing they are part of the same LAN network. If you connect the CCTV machine to AirVPN (I'm guessing, to be able to watch CCTV when you're not home), MX Linux disconnects and can't reconnect?
It all should work actually, if they're in the same network. Maybe Network Lock on the CCTV is all you need to disable.
-- okay, I will run it again and attach the log...
-- I botched this one again, I mean; (1) MX Linux as my Main IT Workstation, (2) Ubuntu Mate as a Surveillance Camera setup using USB Webcams (using ZoneMinder) with Eddie installed (this one is in the garage using WiFi to connect to the Router).  When Eddie connects then (1) is disconnected and can't reconnect or when I'm connected to (2) and Eddie connects I'm disconnected.
additional info
Here's the logs attempting to connecting from my Laptop via HotSpot on Mobile:
I 2022.03.04 14:17:21 - Session starting.
I 2022.03.04 14:17:21 - Checking authorization ...
. 2022.03.04 14:17:22 - IPv6 disabled on network adapter (default)
. 2022.03.04 14:17:22 - IPv6 disabled on network adapter (wlan0)
! 2022.03.04 14:17:22 - Connecting to Alkurhah (Canada, Toronto, Ontario)
. 2022.03.04 14:17:22 - OpenVPN > OpenVPN 2.5.1 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2021
. 2022.03.04 14:17:22 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2022.03.04 14:17:22 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.04 14:17:22 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.04 14:17:22 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.04 14:17:22 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.04 14:17:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.205:443
. 2022.03.04 14:17:22 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2022.03.04 14:17:22 - OpenVPN > UDP link local: (not bound)
. 2022.03.04 14:17:22 - OpenVPN > UDP link remote: [AF_INET]184.75.221.205:443
. 2022.03.04 14:17:22 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.205:443, sid=0b870eaf 8126bced
. 2022.03.04 14:17:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.04 14:17:22 - OpenVPN > VERIFY KU OK
. 2022.03.04 14:17:22 - OpenVPN > Validating certificate extended key usage
. 2022.03.04 14:17:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.04 14:17:22 - OpenVPN > VERIFY EKU OK
. 2022.03.04 14:17:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alkurhah, emailAddress=info@airvpn.org
. 2022.03.04 14:17:22 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.04 14:17:22 - OpenVPN > [Alkurhah] Peer Connection Initiated with [AF_INET]184.75.221.205:443
. 2022.03.04 14:17:23 - OpenVPN > SENT CONTROL [Alkurhah]: 'PUSH_REQUEST' (status=1)
. 2022.03.04 14:17:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.6.222.1,dhcp-option DNS6 fde6:7a:7d20:2de::1,tun-ipv6,route-gateway 10.6.222.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:2de::1038/64 fde6:7a:7d20:2de::1,ifconfig 10.6.222.58 255.255.255.0,peer-id 10,cipher AES-256-GCM'
. 2022.03.04 14:17:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.04 14:17:23 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:2de::1'
. 2022.03.04 14:17:23 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2022.03.04 14:17:23 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:2de::1038/64 fde6:7a:7d20:2de::1'
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.04 14:17:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.04 14:17:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.04 14:17:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.04 14:17:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.04 14:17:23 - OpenVPN > net_route_v4_best_gw query: dst 0.0.0.0
. 2022.03.04 14:17:23 - OpenVPN > net_route_v4_best_gw result: via 192.168.237.247 dev wlan0
. 2022.03.04 14:17:23 - OpenVPN > ROUTE_GATEWAY 192.168.237.247/255.255.255.0 IFACE=wlan0 HWADDR=38:ba:f8:d1:82:56
. 2022.03.04 14:17:23 - OpenVPN > TUN/TAP device tun0 opened
. 2022.03.04 14:17:23 - OpenVPN > net_iface_mtu_set: mtu 1500 for tun0
. 2022.03.04 14:17:23 - OpenVPN > net_iface_up: set tun0 up
. 2022.03.04 14:17:23 - OpenVPN > net_addr_v4_add: 10.6.222.58/24 dev tun0
. 2022.03.04 14:17:28 - OpenVPN > net_route_v4_add: 184.75.221.205/32 via 192.168.237.247 dev [NULL] table 0 metric -1
. 2022.03.04 14:17:28 - OpenVPN > net_route_v4_add: 0.0.0.0/1 via 10.6.222.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:17:28 - OpenVPN > net_route_v4_add: 128.0.0.0/1 via 10.6.222.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:17:28 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2022.03.04 14:17:28 - Routes, added a new route, 184.75.221.203 for gateway 10.6.222.1
. 2022.03.04 14:17:28 - Unable to compute route for 2606:6080:1001:16:3492:5f11:f1fb:66ae: IPv6 VPN gateway not available.
. 2022.03.04 14:17:28 - Flushing DNS
I 2022.03.04 14:17:28 - Checking route IPv4
. 2022.03.04 14:17:48 - curl: (28) Operation timed out after 20001 milliseconds with 0 bytes received
. 2022.03.04 14:17:48 - Checking route (2° try)
. 2022.03.04 14:18:09 - curl: (28) Operation timed out after 20000 milliseconds with 0 bytes received
. 2022.03.04 14:18:09 - Checking route (3° try)
. 2022.03.04 14:18:31 - curl: (28) Operation timed out after 20001 milliseconds with 0 bytes received
E 2022.03.04 14:18:31 - Checking route IPv4 failed.
. 2022.03.04 14:18:31 - OpenVPN > Initialization Sequence Completed
! 2022.03.04 14:18:31 - Disconnecting
. 2022.03.04 14:18:32 - Routes, removed a route previously added, 184.75.221.203 for gateway 10.6.222.1
. 2022.03.04 14:18:32 - Sending soft termination signal
. 2022.03.04 14:18:32 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2022.03.04 14:18:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.04 14:18:38 - OpenVPN > net_route_v4_del: 184.75.221.205/32 via 192.168.237.247 dev [NULL] table 0 metric -1
. 2022.03.04 14:18:38 - OpenVPN > net_route_v4_del: 0.0.0.0/1 via 10.6.222.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:18:38 - OpenVPN > net_route_v4_del: 128.0.0.0/1 via 10.6.222.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:18:38 - OpenVPN > Closing TUN/TAP interface
. 2022.03.04 14:18:38 - OpenVPN > net_addr_v4_del: 10.6.222.58 dev tun0
. 2022.03.04 14:18:38 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.04 14:18:38 - Connection terminated.
. 2022.03.04 14:18:38 - IPv6 restored on network adapter (default)
. 2022.03.04 14:18:38 - IPv6 restored on network adapter (wlan0)
. 2022.03.04 14:18:38 - DNS of the system restored to original settings (Rename method)
I 2022.03.04 14:18:41 - Checking authorization ...
. 2022.03.04 14:18:42 - IPv6 disabled on network adapter (default)
. 2022.03.04 14:18:42 - IPv6 disabled on network adapter (wlan0)
! 2022.03.04 14:18:42 - Connecting to Mintaka (Canada, Toronto, Ontario)
. 2022.03.04 14:18:42 - OpenVPN > OpenVPN 2.5.1 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2021
. 2022.03.04 14:18:42 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2022.03.04 14:18:42 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.04 14:18:42 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.04 14:18:42 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.04 14:18:42 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.04 14:18:42 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.221:443
. 2022.03.04 14:18:42 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2022.03.04 14:18:42 - OpenVPN > UDP link local: (not bound)
. 2022.03.04 14:18:42 - OpenVPN > UDP link remote: [AF_INET]184.75.223.221:443
. 2022.03.04 14:18:42 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.221:443, sid=8552f332 231e0e7b
. 2022.03.04 14:18:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.04 14:18:42 - OpenVPN > VERIFY KU OK
. 2022.03.04 14:18:42 - OpenVPN > Validating certificate extended key usage
. 2022.03.04 14:18:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.04 14:18:42 - OpenVPN > VERIFY EKU OK
. 2022.03.04 14:18:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mintaka, emailAddress=info@airvpn.org
. 2022.03.04 14:18:42 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.04 14:18:42 - OpenVPN > [Mintaka] Peer Connection Initiated with [AF_INET]184.75.223.221:443
. 2022.03.04 14:18:43 - OpenVPN > SENT CONTROL [Mintaka]: 'PUSH_REQUEST' (status=1)
. 2022.03.04 14:18:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.30.1,dhcp-option DNS6 fde6:7a:7d20:141e::1,tun-ipv6,route-gateway 10.24.30.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:141e::1060/64 fde6:7a:7d20:141e::1,ifconfig 10.24.30.98 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2022.03.04 14:18:43 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.04 14:18:43 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:141e::1'
. 2022.03.04 14:18:43 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2022.03.04 14:18:43 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:141e::1060/64 fde6:7a:7d20:141e::1'
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.04 14:18:43 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.04 14:18:43 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.04 14:18:43 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.04 14:18:43 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.04 14:18:43 - OpenVPN > net_route_v4_best_gw query: dst 0.0.0.0
. 2022.03.04 14:18:43 - OpenVPN > net_route_v4_best_gw result: via 192.168.237.247 dev wlan0
. 2022.03.04 14:18:43 - OpenVPN > ROUTE_GATEWAY 192.168.237.247/255.255.255.0 IFACE=wlan0 HWADDR=38:ba:f8:d1:82:56
. 2022.03.04 14:18:43 - OpenVPN > TUN/TAP device tun0 opened
. 2022.03.04 14:18:43 - OpenVPN > net_iface_mtu_set: mtu 1500 for tun0
. 2022.03.04 14:18:43 - OpenVPN > net_iface_up: set tun0 up
. 2022.03.04 14:18:43 - OpenVPN > net_addr_v4_add: 10.24.30.98/24 dev tun0
. 2022.03.04 14:18:48 - OpenVPN > net_route_v4_add: 184.75.223.221/32 via 192.168.237.247 dev [NULL] table 0 metric -1
. 2022.03.04 14:18:48 - OpenVPN > net_route_v4_add: 0.0.0.0/1 via 10.24.30.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:18:48 - OpenVPN > net_route_v4_add: 128.0.0.0/1 via 10.24.30.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:18:48 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2022.03.04 14:18:48 - Routes, added a new route, 184.75.223.219 for gateway 10.24.30.1
. 2022.03.04 14:18:48 - Unable to compute route for 2606:6080:1002:7:def:437f:f6fa:7759: IPv6 VPN gateway not available.
. 2022.03.04 14:18:48 - Flushing DNS
I 2022.03.04 14:18:48 - Checking route IPv4
. 2022.03.04 14:19:08 - curl: (28) Operation timed out after 20001 milliseconds with 0 bytes received
. 2022.03.04 14:19:08 - Checking route (2° try)
. 2022.03.04 14:19:29 - curl: (28) Operation timed out after 20001 milliseconds with 0 bytes received
. 2022.03.04 14:19:29 - Checking route (3° try)
. 2022.03.04 14:19:51 - curl: (28) Operation timed out after 20001 milliseconds with 0 bytes received
E 2022.03.04 14:19:51 - Checking route IPv4 failed.
. 2022.03.04 14:19:51 - OpenVPN > Initialization Sequence Completed
! 2022.03.04 14:19:51 - Disconnecting
. 2022.03.04 14:19:51 - Routes, removed a route previously added, 184.75.223.219 for gateway 10.24.30.1
. 2022.03.04 14:19:51 - Sending soft termination signal
. 2022.03.04 14:19:51 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2022.03.04 14:19:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.04 14:19:56 - OpenVPN > net_route_v4_del: 184.75.223.221/32 via 192.168.237.247 dev [NULL] table 0 metric -1
. 2022.03.04 14:19:56 - OpenVPN > net_route_v4_del: 0.0.0.0/1 via 10.24.30.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:19:56 - OpenVPN > net_route_v4_del: 128.0.0.0/1 via 10.24.30.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:19:56 - OpenVPN > Closing TUN/TAP interface
. 2022.03.04 14:19:56 - OpenVPN > net_addr_v4_del: 10.24.30.98 dev tun0
. 2022.03.04 14:19:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.04 14:19:56 - Connection terminated.
. 2022.03.04 14:19:56 - IPv6 restored on network adapter (default)
. 2022.03.04 14:19:56 - IPv6 restored on network adapter (wlan0)
. 2022.03.04 14:19:56 - DNS of the system restored to original settings (Rename method)
I 2022.03.04 14:19:59 - Checking authorization ...
. 2022.03.04 14:20:00 - IPv6 disabled on network adapter (default)
. 2022.03.04 14:20:00 - IPv6 disabled on network adapter (wlan0)
! 2022.03.04 14:20:00 - Connecting to Aludra (Canada, Toronto, Ontario)
. 2022.03.04 14:20:00 - OpenVPN > OpenVPN 2.5.1 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2021
. 2022.03.04 14:20:00 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2022.03.04 14:20:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.04 14:20:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.04 14:20:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.04 14:20:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.04 14:20:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.205:443
. 2022.03.04 14:20:00 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2022.03.04 14:20:00 - OpenVPN > UDP link local: (not bound)
. 2022.03.04 14:20:00 - OpenVPN > UDP link remote: [AF_INET]104.254.90.205:443
. 2022.03.04 14:20:00 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.205:443, sid=bfaa3c8c 4d2b8934
. 2022.03.04 14:20:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.04 14:20:00 - OpenVPN > VERIFY KU OK
. 2022.03.04 14:20:00 - OpenVPN > Validating certificate extended key usage
. 2022.03.04 14:20:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.04 14:20:00 - OpenVPN > VERIFY EKU OK
. 2022.03.04 14:20:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aludra, emailAddress=info@airvpn.org
. 2022.03.04 14:20:00 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.04 14:20:00 - OpenVPN > [Aludra] Peer Connection Initiated with [AF_INET]104.254.90.205:443
. 2022.03.04 14:20:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.94.1,dhcp-option DNS6 fde6:7a:7d20:45e::1,tun-ipv6,route-gateway 10.8.94.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:45e::10d1/64 fde6:7a:7d20:45e::1,ifconfig 10.8.94.211 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2022.03.04 14:20:01 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.04 14:20:01 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:45e::1'
. 2022.03.04 14:20:01 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2022.03.04 14:20:01 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:45e::10d1/64 fde6:7a:7d20:45e::1'
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.04 14:20:01 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.04 14:20:01 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.04 14:20:01 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.04 14:20:01 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.04 14:20:01 - OpenVPN > net_route_v4_best_gw query: dst 0.0.0.0
. 2022.03.04 14:20:01 - OpenVPN > net_route_v4_best_gw result: via 192.168.237.247 dev wlan0
. 2022.03.04 14:20:01 - OpenVPN > ROUTE_GATEWAY 192.168.237.247/255.255.255.0 IFACE=wlan0 HWADDR=38:ba:f8:d1:82:56
. 2022.03.04 14:20:01 - OpenVPN > TUN/TAP device tun0 opened
. 2022.03.04 14:20:01 - OpenVPN > net_iface_mtu_set: mtu 1500 for tun0
. 2022.03.04 14:20:01 - OpenVPN > net_iface_up: set tun0 up
. 2022.03.04 14:20:01 - OpenVPN > net_addr_v4_add: 10.8.94.211/24 dev tun0
. 2022.03.04 14:20:06 - OpenVPN > net_route_v4_add: 104.254.90.205/32 via 192.168.237.247 dev [NULL] table 0 metric -1
. 2022.03.04 14:20:06 - OpenVPN > net_route_v4_add: 0.0.0.0/1 via 10.8.94.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:20:06 - OpenVPN > net_route_v4_add: 128.0.0.0/1 via 10.8.94.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:20:06 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2022.03.04 14:20:06 - Routes, added a new route, 104.254.90.203 for gateway 10.8.94.1
. 2022.03.04 14:20:06 - Unable to compute route for 2606:6080:2001:7:5c45:9163:ab64:25f3: IPv6 VPN gateway not available.
. 2022.03.04 14:20:06 - Flushing DNS
I 2022.03.04 14:20:06 - Checking route IPv4
. 2022.03.04 14:20:26 - curl: (28) Operation timed out after 20001 milliseconds with 0 bytes received
. 2022.03.04 14:20:26 - OpenVPN > Initialization Sequence Completed
! 2022.03.04 14:20:26 - Disconnecting
. 2022.03.04 14:20:26 - Routes, removed a route previously added, 104.254.90.203 for gateway 10.8.94.1
. 2022.03.04 14:20:26 - Sending soft termination signal
. 2022.03.04 14:20:26 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2022.03.04 14:20:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.04 14:20:31 - OpenVPN > net_route_v4_del: 104.254.90.205/32 via 192.168.237.247 dev [NULL] table 0 metric -1
. 2022.03.04 14:20:31 - OpenVPN > net_route_v4_del: 0.0.0.0/1 via 10.8.94.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:20:31 - OpenVPN > net_route_v4_del: 128.0.0.0/1 via 10.8.94.1 dev [NULL] table 0 metric -1
. 2022.03.04 14:20:31 - OpenVPN > Closing TUN/TAP interface
. 2022.03.04 14:20:31 - OpenVPN > net_addr_v4_del: 10.8.94.211 dev tun0
. 2022.03.04 14:20:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.04 14:20:31 - Connection terminated.
. 2022.03.04 14:20:31 - IPv6 restored on network adapter (default)
. 2022.03.04 14:20:31 - IPv6 restored on network adapter (wlan0)
. 2022.03.04 14:20:31 - DNS of the system restored to original settings (Rename method)
I 2022.03.04 14:20:31 - Cancel requested.
! 2022.03.04 14:20:31 - Session terminated.
